Now just to clarrify about the PRV
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,375
    Default Now just to clarrify about the PRV
    Where the bottom ends through the range of volvo, peugeot and Renult's the same with just differnt top halfs and accesseries...
    Im getting a whole hord of conflicting imformation here..
    Actually spoke to my mechanic and he nearly slapped me for even thinking aout putting a V6 from the volvo in my pug.. He actually gave one away with 80,000kms on the clock gearbox and all out of a 260 as he couldn't be ****ed with the drama they casue
    Like what..
    I though it was only the heads and differing inlets that caused all the drama's
    He was complaining about them leaking all over the palce.. and not being half as strong as every one seemed to talk up..
    He actually suggust i find a Pug PRV.. and put a Rrnult head atop and leave it as such..
    so who can clear this cunfundled crap up..?? "whimper"
    are the Pug and Volov Even fire bottomes differnt?
    12,256
    Quote Originally Posted by bowie
    Like what..
    have a look in the citroen section under the thread about buying a new xantia V6 and look at the sight that i have linked in there
    you will find many of the stoires you have been told answered in there but in short the PRV bottem ends from a pug or volvo are the same
    you mention volvo to most people and they cringe as volvo had a bad run due to bad servicing of their cars compared to pugs and they also ran taps (brass mind you, now think electrolisis with alloy here and the fact you could never drain the coolant properly compared to the pug variant)
    volvo ran 20k services compared to pugs 10k and as such old oil would kill the LH camshaft and rockers (leads to another story)
    the oil supply problem is an easy fix and the wear problem is easily avoided by regular oil changes regardless (der we all know that but the bloody volvo makers didn't)
    1 x '98 306 GTi6
    Aug 2002
    3,375
    Cheers mate.. i thought that was what all the gripe was about.. thank you.
    Fellow Frogger! OddFireV6's Avatar
    152
    Bowie
    If you have accurately represented you mechanic's comments he is not correct. For given years and model the PRVs are identical, all manufaturers offered the same range of sizes and compression options etc and induction systems. The only exception to this was some of the Alpine arrangements.
    FYI someone said that Deloreans were Volvo Motors, this is no more true than to say they were twin plenum K injection motors as in 604 TIs, the sump used in Deloreans was that found in Renualt Alpines or 30s.
    The reason Volvo's are most referred to is because of availability, there are just more of them here. For the reasons Pugrambo mentioned above you need to lookout for corrossion and cam failure, by the way this appears not to have been a problem in the 5 even fires (B280s) I have now seen apart.
    OddfireV6
    504 V6 24V, 203
    farmerdave
    Guest
    Oil leaks can be prevented by assembling with a very small amount of hylomar- the modular design means that there are plenty of joints.
    Service interval- as late as 1980 renault recommended a 7500km change for the PRV,and oil no thicker than 15-40w- maybe they knew something about the engine?. Interval went to 10,000 by 1985 for non-turbo cars.
    Farmerdave
    Aug 2002
    3,375
    Bowie
    If you have accurately represented you mechanic's comments he is not correct. For given years and model the PRVs are identical, ......
    well indeedy.. i was a bit complexed after he gave me the coldest shoulder fo all time after i mentined the letters PRV with volvo as the prefix..
    Thanks again ..
