Oil Temperature for Mi16 on the track?
Results 1 to 25 of 41
    Cal
    Cal is offline
    Moderator Cal's Avatar
    Jan 2002
    1,624
    Default Oil Temperature for Mi16 on the track?
    Calling Peter T and other Mi16 S1 engine experts. I don't usually use the Mi16 on the track as I have the MX5 for that purpose. However, yesterday I took it out to Morgan Park for a track day. Previously I have only done short burst events in it like a hillclimb and a motorkhana. I therefore have never used prelonged high revs. On a hard run through the hills, I would rarely get the oil above 100-110 degrees. However on the track it wanted to climb higher. Once it got to 120 I would come in and let it cool down. Is that too high? I use Mobil 1 and the oil is fresh and up to the top of the dipstick. I was very happy indeed with the old girl on the track. Surprised a few Westfields (the club I was out with) believe it or not. Enjoyed it so much I will probably take it out more often. Hmmm think I will be needing a Peter T camshaft sooner than I thought.
    Cal.
    1995 Mazda MX5 - 2F Race Car
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1971 Morris Mini 1100K
    1967 Porsche 911S
    1957 Porsche 356A Speedster Replica
    1000+ Posts brenno's Avatar
    1,937
    Glad to hear you enjoyed it. What about the water temp?
    Cal
    Cal is offline
    Jan 2002
    1,624
    Water temp didn't do anything. Sat at about 70-80.
    Cal.
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1967 Porsche 911S
    7,446
    Yes, that's too high. You need a dedicated oil cooler otherwise you'll spin a bearing, regardless of the oil you use. Big end #1, furthest from the pump, will die first.
    You also need a baffled sump. That's an even bigger priority. Otherwise, it's well and truely goodbye with a 16V head. I still make them on an exchange basis.
    Cal
    Cal is offline
    Jan 2002
    1,624
    Thanks Peter. I knew a baffled sump would be a good idea. I don't imagine I could have done too much damage in an afternoon. Hope not anyhow.
    Cal.
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1967 Porsche 911S
    1000+ Posts David Shearer's Avatar
    Glenroy
    1,141
    Quote Originally Posted by Cal
    Cal.
    I'm taking my Mi out on the track for one day next month and wondering what would be the oil temp I should be keeping it at. Don't have an oil cooler or baffled sump. I don't intend to drive it really hard but don't want to do a bearing either. Should I get a new dipstick for the day so I can keep measuring oil levels etc??
    Dave
    78 Fiat X1/9, Peugeot 406 ST, Peugeot 407 V6 SW
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Peugeot, Francais pour "Putain qu'c'est vite"[/FONT]
    7,446
    Quote Originally Posted by David Shearer
    Dave
    An Mi16 with sticky tyres and no sump baffle = no bearings. You'll soon get carried away and forget about the oil pressure and temp.
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    What about 8 Valves? are they as prone to failing?
    Dave
    7,446
    Quote Originally Posted by Dave
    Dave
    Not as much, but the danger is still there on right handers. The 16V retains a lot more oil in the head due to the extra valves and hydraulic lifters.
    Apr 2001
    1,340
    That would probably explain why on our other bx's (the ones that use oil) start to do thier beepy thing around round-abouts (right hand turn) when they get low on oil
    Glad mine doesn't use any.
    Dave
    Cal
    Cal is offline
    Jan 2002
    1,624
    When you say that, do you mean after a couple of years of track events or after one day? How would I know if I have damaged anything? I did probably 40 laps of which most of the corners are right handers. I was driving very hard, but not really reving the engine too high. Morgan Park is a momentum circuit. I rarely hit 7000rpm.
    Cal.
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1967 Porsche 911S
    7,446
    Cal.
    One corner with no oil. Long RH sweepers are the worst. As Mi16's don't have an oil pressure guage it's hard to tell. On a 205 you can tell from the oil pressure, the difference between stuffed bearings and good ones.
    I'd just be making a baffle sump a priority. It's easy to change. While it's off you can inspect and/or replace the bearings.
    1,937
    Is that what it is? Didn't know that. I thought it was some suspension fault or something. It's only happened a couple of times on tight roundabouts.
    Apr 2001
    1,340
    Top up the oil brenno!!
    Assuming all the warning lights/beeps etc are the same in the 16V as in the tri and TZI. My GT is a little older so no annoying beep.
    Dave
    Glenroy
    1,141
    Hmmmmmm,
    I'm thinking of going to Winton or Calder park.
    So perhaps, I should just take it easy and keep checking the oil
    Previous:
    05 Megane Turbo
    2x 89 405 Mi16
    67 404
    Cal
    Cal is offline
    Jan 2002
    1,624
    Sounds like turn 1 at QR could be a problem. I highly doubt any damage was done the other day. There are 2X right hand 2nd gear corners that come back on themselves. You brake hard in a straight line, back to 2nd and into the corner, settle the car and back on it. They are tight and quite slow. You'd be back in a straight line before you even hit 5000rpm. I would have thought the engine would have to be reving hard to damage the bearings.
    How much are these exchange sumps?
    Cal.
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1967 Porsche 911S
    7,446
    $150. I'm not just trying to sell a sump either. It really is a problem. Every XU9 competition engine I know that's run without a baffle and/or proper oil cooling has failed. Matt205 is the latest. His alternator failed because of the conrod jammed in it.
    Cal
    Cal is offline
    Jan 2002
    1,624
    Oh wouldn't think you were for a second. At that price you are hardly going to get rich selling a couple a year to some punters on Froggy.
    So how would I know if I've damaged my bearings? Wouldn't it get rattly in the bottom end? You'd hear it no?
    Cal.
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1967 Porsche 911S
    NSW
    1,063
    When I pulled my engine apart to do the rebuild the bearings in my engine were absolutely rooted. I have no idea how bad they were before I did 1 track day but they were definately very second hand after it.
    A baffled sump makes all the difference. No such problems now.
    7,446
    If you can here it, you've damaged the crank. If you can't, you can probably save it by fitting new bearings.
    Gordon, NSW
    4,527
    Quote Originally Posted by MYT205
    How would this have affected the J4RS engine? It's temps stayed fairly normal when we were at Wakefield that day. Should we be checking the bearings?
    7,446
    Quote Originally Posted by GTI124
    The XU10J4 engines have baffled sumps.
    Jun 2004
    396
    mine went a little while ago at a motorkhana, the slippers on #1 (i think thats the cam belt end) were melted to the crank. after six hard runs with no break, a baffle with a leaky flap, no oil cooler, and a little less oil than i should have had, the whole engine siezed when i pushed the clutch in.
    all that is now fixed, with the exception of the oil cooler.
    now this is the part where you give me suggestions about what oil cooler to fit, and how.
    i was thinking of mounting it the same way i was going to do my r12 cooler. mount it on a bracket in front of the battery and have an intake vent above it in the bonnet. this would be in the second bonnet, as the road going bonnet has no vents or pins. or is it much simpler and easier to mount it to the radiator?
    Gordon, NSW
    4,527
    Thanks Peter.
    7,446
    Quote Originally Posted by 3006882
    I'd just get it in some clean air flow, in front of the radiator. If you don't have an AC condensor there should be plenty of room.
