fuel inrichment
Results 1 to 18 of 18
Thread: fuel inrichment
    Jul 2004
    torquay vic
    34
    Default fuel inrichment
    i am puting a twin turbo even fire in my my 505 sti 1985 and i am going to run the standed ECUs (computers) and i was wanting to know if there was any way of geting the standed computer to enrichen the fuel when undender boost or if you can add on a fuel enrichment system to the exstisting computer or system and does any one know how i can make a fuel enrichment system or where i can bye one and what is the best way to get around this problem so if any one can help me it please pm me or email me on [email protected] or pm me
    thanks guys hope you can help me
    cheers
    Fellow Frogger! OddFireV6's Avatar
    152
    Craig thats a familiar sounding idea!
    For EFI I suggest you look at the Megasquirt computer (look at there website) and toss the Volvo CPU aside.
    OddfireV6
    504 V6 24V, 203
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,376
    yes would have to be far easier in the long run just having an aftermakert ECU controlling everything then trying to tell the volvo via some picky back syetem..
    The flexability of an ECU will keep you smiling as you up the boost to silly amounts..
    7,448
    Buy an early fuel only Haltech such as the F3. They go for approx. US$150 on Ebay.
    9,185
    Quote Originally Posted by OddFireV6
    My Megasquirt kit arrived on Friday, I'll be trying it out on the 205 GTI first.
    After unclipping the original ECU , it still ran and started, today it wouldn't go!!
    Mybe I'll have to fit the Megasquirt before it runs again?
    It does have an immobiliser, pretty badly fitted, maybe a wire has come loose somewhere.
    Graham
    Fellow Frogger! aquinian's Avatar
    WA
    604
    Quote Originally Posted by craig latta
    cheers
    Craig,
    Let me know how you go with the CPU question. I'm adding turbos to my 505 V6 also, and am presently investigating fuel and ignition control issues. I have the 2.7l odd-fire with K-Jetronic injection. I think the "easy" (read: "easier"?) solution will be to go to L-Jetronic with an after-market computer. I'm told we could run it off the dizzie signal, thus avoiding the challenge of fitting a crank-shaft sensor. Anybody know if that makes sense?
    Rob? What do you think?
    John Lane.
    7,448
    Quote Originally Posted by aquinian
    Craig,
    John Lane.
    That's correct. The L Jetronic fires off the negative side of the coil (like a tacho). Or in other words, a square wave 12 volt input. Most aftermarket ECU's will fire the same way.
    12,256
    Craig,
    John Lane.
    did you notice on your block there was a plug in the centre at the rear in the valley that you can place the sensor ?
    i know it is hard to get to now and also will be time consuming to get to the flywheel but the provision is there if need be
    BTW how is the yella terra going ?
    1 x '98 306 GTi6
    9,185
    Yes, the megasquirt does this.
    I should have my ZDJL going with this in a matter of days.
    Graham
    12,256
    i also jsut remembered you can also put a sensor on the cover plate at the bottom of the bell housing
    1 x '98 306 GTi6
    WA
    604
    Hi Sean,
    Yes, the hole below the plug is for locating top dead centre when you're building the motor. But a sensor has to sense something, so you'd need to attach something (or things) to the flywheel. I think the dizzy feed is easier.
    The yellow terror is not nearly terrifying enough. Two WRX turbos ought to fix that, at least for a few months...
    Thanks for the reply, Peter. I'm probably going to get the boys at Rotomotion to fit the turbos and tune it. They're legends.
    Btw, I spoke to a bloke called Garry Ruben from the S.A. Pug club the other day, and again today, he claims to have a 504 with a supercharged V6 which produces (are you sitting down?) 840bhp at the flywheel. I asked him for the dyno chart and he promised to email it. 0-100 km/h in 3.8 seconds, and sub-10 second quarter miles. And it is licensed. Well, it pretends to be until the cops pull it over...
    I am suspending belief on this until I've driven it.
    Anybody know Garry Ruben in S.A.?
    John Lane.
    12,256
    Hi Sean,
    John Lane.
    yes you still have to attach something to the flywheel but there is a hole that is plugged up at the rear of the engine on the vertical face for a pick up to be attached as the later models utilised this
    yes i had gary ruben call me one night searching for an alternator for his 604 while he was in crookwell one cold night
    1 x '98 306 GTi6
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    I'm probably going to get the boys at Rotomotion to fit the turbos and tune it. They're legends..
    Say hello to Graeme Stones for me, unless he's sold the business.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    Do the 505 STi motors use AFM, MAP or MAF to monitor the airflow?
    In either case you can get a piggy back unit to adjust the factory Air flow controller to suit the new turbo application.
    Units like Split Second PSC1-003 (MAF) PSC1-001 (MAP) would do the job, or even the more rice orientated APEXI SAFC units or Unichip on the more expensive side.
    9,185
    Quote Originally Posted by tekkie
    The STI motor uses a mechanical AFM. This is a mechanical system in spite of the name! The AFM simply varies the amount of fuel flow, the injectors continuously squirt fuel. "K" is the initial for the word meaning continuous in German.
    Graham
    WA
    604
    i am puting a twin turbo even fire ...
    Craig,
    How did you go? Any progress? And what about ignition control?
    John Lane.
    con
    con is offline
    sydney, nsw, australia
    503
    Hi Sean,
    John,
    The 505 evenfire "LHjet" uses the square cutouts on the circumference of the flywheel to determine the top dead centre (and timing). See attachment.
    I do have a factory description somewhere; if only I could lay my hands on it....
    con....
    Fellow Frogger! 505 to the max's Avatar
    Newcastle
    380
    Default Even fire V6
    I would suggest nothing less than a complete fuel and ignition ECU used in conjunction with standard injectors (I'm told that Volvo injectors are always more than adequate for factory power outputs), and a rising rate fuel pressure regulator. If boost is involved the last thing you want is a damaged piston due to lean mixtures under load. If it was me I'd be more than willing to spend the extra cash on a fully remappable (fuel and ignition)ECU as you can milk a lot more power from your engine and it also gives you the ability to retard timing at exact load points if you detect detonation. The ECU I have on my car (505GR with GTi motor, approx 160hp) uses the standard reluctor type distributor as a trigger. The only mod needed is to remove the vacuum and mechanical advance. I don't know much about the V6 (at least that it has 6 cylinders) but if it has the same type of distributor this may help.
