K&N induction kit - Heat shield
    Fellow Frogger! kaiser's Avatar
    Sep 2003
    Canberra ACT
    393
    Default K&N induction kit - Heat shield
    Hi Ppl
    I have just bought a car that has a K&N Induction kit in it. While it sounds great I doubt if its doing any good because of the hot air going into it from the radiator. Any thoughts on how to shield the air, DIY?
    Ky
    Attached Thumbnails Attached Thumbnails K&N induction kit - Heat shield-picture-001.jpg   K&N induction kit - Heat shield-picture-009.jpg
    1000+ Posts CHRI'S16's Avatar
    Jun 2002
    3,298
    Hi kaiser, you could purchase some flexible foil backed foam and shape it so that only colder air enters. In the photos is it some form of tubing/piping that enters from below that you can only just see under the actual filter, if so you could have it so that the only exposed part is this tubing.... what car did you buy 406V6? Cheers-Chris
    ... ptui!
    1,160
    foam around heat???
    make sure it can withstand the heat!
    Jun 2002
    3,298
    Quote Originally Posted by nate
    foam around heat???
    ...its a Refrigeration product, I use it at work but havn't the foggiest were we used to get it from. They handle the heat of the compressor head very well, so under bonnet temps etc shouldn't be a problem.-Chris
    ... ptui!
    Fellow Frogger! Jason20's Avatar
    Oct 2003
    Sydney, Australia
    439
    use an esky bro! I was faced with the same problem on my 405, theres not much room in there... alot of new cars have pod filters inside a plastic cylindrical shell as stock from the factory. maybe you could mix & match one from another car or make something similar.
    Sep 2003
    Canberra ACT
    393
    Thanks Guys
    I might try something similar to the attached pic, just got to find a suitable product. I was thinking of some heater duct.
    Ps its a 99 Coupe
    Ky
    Attached Thumbnails Attached Thumbnails K&N induction kit - Heat shield-pipercross-viper-carbon-v6-custom-install.jpg
