any one know any thing about :pugplak: 505 turbo diesels
    Jul 2004
    torquay vic
    34
    Icon1 any one know any thing about :pugplak: 505 turbo diesels
    i have a 505 s2 turbo diesel i like the econamy but she needs to go a bit harder uping the boast is easy does any body what many be a safe limt ive had a boost gauge on and it only runs around 9 lb where as my old hdi use to boost to 15 lb bye 2000rpm i presume it would all so need more diesel but i cant seem to find any info on how modify the injection pump if any body has under taken a simuler project or has any clues that would be very helpfull so please pm me or email me on [email protected]
    cheers
    thanks guys thanks
    nathan and craig latta
    12,256
    Quote Originally Posted by craig latta
    i have a 505 s2 turbo diesel i like the econamy but she needs to go a bit harder uping the boast is easy does any body what many be a safe limt ive had a boost gauge on and it only runs around 9 lb where as my old hdi use to boost to 15 lb bye 2000rpm i presume it would all so need more diesel but i cant seem to find any info on how modify the injection pump if any body has under taken a simuler project or has any clues that would be very helpfull so please pm me or email me on crai[email protected]
    cheers
    thanks guys thanks
    you can fuel it up a bit more but the EPA or the POlice could get on your back for excessive smoke
    i have modified many a truck and diesel car in my time but i generally only do it for friends knowing if they get caught i don't cop the fine for fiddling with the pump as they are wired to prevent such mods as you may have noticed on your pump
    have a play and see what you come up with as it is pretty simple and just about every older truck onthe road has been fiddled and re-wired or just pulled the lever off the splined shaft and put back on a notch or 2 out to fuel it up a bit more
    modern diesels are harder especially the huei cats as they are run by oil pressure and computers
    1 x '98 306 GTi6
    Dec 2002
    CANBERRA
    399
    Hi, I can provide details of how to adjust the pump as it is the same as a Landrover Discovery and there is good detail on Landrover sites.
    As Pugrambo says, however, it is hard to get more grunt without ending up with more smoke, particulary under hard throttle. I have had good improvements on the Disco with an improved intercooler and modest pump adjustments but under extreme throttle openings there is a bit more smoke.
    Jim
    Aug 2002
    1,290
    wouldnt describe it as a bit Jim the day you drove away from my Place. I thought it was the end of the world as the middle of the day became black
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Dec 2002
    CANBERRA
    399
    Now be nice, I've wound it back since then!!
