205 gear knob
Results 1 to 9 of 9
Thread: 205 gear knob
    Jul 2004
    nth balwyn, victoria
    1,428
    Default 205 gear knob
    ok so whats the go ,how does the gear shift knob come off on the 205,i took off the oval top plate ,cant see a nut to loosen.does the knob twist off the gear stick[tried this but seems to not undo],i didnt try too hard as i didnt want to break it,thanks -BAZZ
    SMP addict pugjet's Avatar
    May 2002
    Enruoblem
    2,098
    hi bazz,
    just like a coke bottle cap - its a twister.
    or you can do what those chiks do in that "legally blonde" film.... you bend.... then snap! .
    current frogs :
    '94 s3 alpine 205GTi
    daily ding magnet: '98 1.8 16v citroen xsara
    previous frogs:
    88 S1 205GTi
    '95 306S16
    gimme corners. . .
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Should this be in the Peugeot forum?
    May 2002
    642
    Turn it a little bit and pull up, hard..the g/knob is located on a spline not a thread, hope that helps.
    05' Megane 225 Cup
    Jul 2004
    1,428
    Quote Originally Posted by Luca
    should what be in the peugeot forum?
    Aug 2002
    1,290
    This has come up before, the general consensus is to grab your knob firmly and pull hard
    Take that anyway you like, however I tried to remove the gear knob in the 405 but had no success, Yes I did grab the gear knob.
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Member McPug's Avatar
    Apr 2003
    95
    I wouldn't reccomend pulling your gear knob off, because it jambs onto a jagged stalk, then after you remove it, it won't go back on very well. It will be loose.
    I found out the hard way because I was bored in traffic and pulled it off, then had to buy a new one. They only cost about $20 for a genuine one with the correct shift pattern on top. So it's not a huge drama anyway.
    Fellow Frogger! Pug-a-lug's Avatar
    Jun 2004
    172
    I replaced my gear knob a few weeks ago, as it was starting to chip and peel away around the shift-pattern diagram.
    Pulling+twisting did it for me.
    Apr 2003
    95
    I got my knob from City Peugeot. About $20. They come with different shift patterns so check what yours is before ordering.
