intake mods
Thread: intake mods
    Member fat bastard's Avatar
    Nov 2002
    Perth WA
    114
    Default intake mods
    Does anyone know of a throttle body and/or afm (I think most early bosch injections systems use variations of the same afm) that I can transplant onto the 205 1.9 git S1. I'd like a cheap alternative to quad throttle bodies, super/turbo charging. I too also hate the bendix brakes I think theyv'e warped the tarox discs I got 15000 kms ago along with greenstuff pads. Tarox said bad luck get them skimmed.
    No need to mention 16 valve upgrade I haven't got $2500. Got to get adjustable shocks and heavy duty clutch.
    Present: 406 petrol 2.0 turbo 97(GB Import), 205 gti 1.9 89, Yamaha TZR250 3xv 93 (Jap Import)
    Past: 205 gti 1.6 1988 (Singpr Import), Citroen 1.9 BX16valve, 405 1.9 mi16, 405 2.0 mi16,
    205 si 93, Mini GT, Datsun SSS x3, Dodge Ram, kingswood, Yamaha TZR250 2ma x2
    Hey mate...You've left your Barina's lights on
    7,446
    Quote Originally Posted by fat bastard
    The 60mm 3.8L Holden TB fits if you're handy in the shed. You'll need to adapt the TPS and block off the idle circuit. I used a 7/16" UNF plug. You'll loose some bottom end torque though. Not sure what you'll do about the AFM though, as I use an aftermarket ECU.
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    I'm gald you could make sence of it...
    Nov 2002
    Perth WA
    114
    Thanks for the replies fellas. Any on replies on afm?
