Resistors
Results 1 to 9 of 9
Thread: Resistors
    Member jumpin_pug's Avatar
    Sep 2003
    Melbourne, Australia
    104
    Default Resistors
    Disclaimer: I purport to know very little about what I'm about to talk about
    I've noticed on ebay that people are selling a 'mod' that claims to give instant hp increases. Upon further investigation these 'mods' comprise of a resistor that is placed before the oxygen sensor (correct me if i'm wrong) that tricks the sensor into thinking that it's receiving cold air so more fuel is introduced or something to that extent.
    Can anyone provide any more detail about installing resistors, whether they are of any benefit/detriment, or any other relevant information...
    cheers
    FOR SALE 1995 PEUGEOT 306S16
    Aug 2002
    1,290
    Get two of the resistors, a couple of hiclones and an energy polarisor and your car will be so economical you will need to go to the service station every day to sell them the extra fuel your car makes
    Neil
    '94 405 SRBT
    '82 CX 2400 Pallas 5spd
    '76 CX Super
    '05 WL Statesman
    '92 HZJ80 Landcruiser
    Fellow Frogger! OddFireV6's Avatar
    152
    The oxygen sensor operates in about the 1 volt and less domain and its response to mixture variations is non linear for which the cpu compensates. I guess that you could theoretically richen the mixture by such an act but I would advise against this, fuel consumption would go up and you may well overshoot ideal the fuel air ratio at some point and you could reduce power at some rev and load conditions. If you are keen on this concept perhaps you should purchase a Powerchip of similar which will give a better result.
    OddfireV6
    504 V6 24V, 203
    Fellow Frogger! MondeoST24's Avatar
    Apr 2004
    121
    Normally these Eaby scams put the resistor on the air temp sensor IIRC and it fools the ECU into thinking it's a cold day so it supplies more fuel- or at least that's the theory.....
    Don't do it... it's just a get rich quick scheme flogging 10 cent resistors for big $$$
    David
    Former 306 S16 owner- now own a Mondeo ST24 V6
    Sep 2003
    104
    thanks for the advice guys...don't worry there was no way I was going to buy one I just wanted to know the principles behind the use of the resistors.
    cheers
    58
    If you want a faster car a quicker safer way would be to put a colder thermostat in. It would keep the car running in warm up mode making it hugely rich - works well on the 4.0L Range Rover/Discovery motors.
    Very effective in making them go like a cut snake while it burns fuel
    by the gallon
    We ususally go from a 88 to a 77 thermo
    Tom
    1000+ Posts tekkie's Avatar
    Jun 2002
    1,516
    Quote Originally Posted by tcns
    by the gallon
    Tom
    wouldnt the change in operating temperture of the engine have negative impact on the longetivity of the unit? I always thought running as close to the oil temp is the way to go.
    58
    Quote Originally Posted by tekkie
    IMO No more than putting a resistor on the temp sensor essentially you are
    you have the same cause and effect ....
    Tom
    Fellow Frogger! AlsPug504's Avatar
    310
    There are devices that change the oxygen sensor output. The main reason for the the use of such a device would to lean the mixture when water injection is added. And compensate for additional oxygen ions in the exhaust gas caused by the presants of water.
    al
