Twin Pulse motors...
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Default Twin Pulse motors...
    Anyone know anything about these?
    Fellow Frogger! sproose16v's Avatar
    263
    I think some Motor bikes have it or something, not too sure.....
    1989 BX 16 Valve Mk1 - SOLD (And Missed)
    http://www.bx16v.cjb.net
    1992 R32 GTSt Skyline
    Fellow Frogger! winnie's Avatar
    123
    Not exactly sure what you are refering to?
    GP bikes have experimented / used cylinder firing to alter the torque 'pulses' from the crank shaft.
    The theory being that it was easier to control rear wheel steer with a 'big bang engine' (2 of the 4 cylinders firing at once to give a torque pulse twice as large but both occuring in one engine rev the other crank rev would have negative torque) than with a 'screamer' engine (traditional cylinder firing even spaced torque pulses). The screamer engines had slightly more peak power and a few other minor advantages that were associated with better/simpler engine harmonics.
    Mar 2003
    1,335
    This was my understanding....
    The smaller cross-sectional area of the multi cylinder allows a more effecient flow into and out of the chamber along with better flame front propagation and less reciprocating mass on each big end bearing. I would also presume that they won't be firing exactly in a v2 order, rather just offsetting the two that fire "together" by a number of degrees in order to reduce shock.
    Member Tim Tech's Avatar
    Jun 2004
    Orange NSW
    36
    Not quite sure what your refering to?
    Are talking about how many cylinders fire at once and when they fire??
    There are two main types of firing sequences:
    Group fire: This is when all cylinders fire as a group at the same time whether or not that cylinder is on its firing stroke
    Sequential fire: This is when only individual cylinders fire when on their firing stroke
    Motorbike and cars can use either of these sequences.
