'Knock me driveshafts!'
Results 1 to 13 of 13
    Fellow Frogger! DJ-Studd's Avatar
    Apr 2003
    Victoria, Australia
    545
    Default 'Knock me driveshafts!'
    Hmm, just wanting to confirm that the KNOCK KNOCK KNOCK when accelerating hard when cornering is the driveshaft?
    What are the driveshafts worth new, from Peugeot of course?
    Ta
    -- DJ
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    I don't think you really want to know.
    What's wrong with rebuilt ones?
    There's a company called "Turner Driveshafts" from Sydney/Newcastle way that I'm pretty sure would do them for a fraction of the price & come with a warranty. I think you'll find they also have agents in Melbourne.
    I can't give you a price but I do know they don't come cheap; I would imagine from Peugeot something above $1500 a side is conceiveable. I'd have it checked thoroughly before you bolted in just in case it's something like a dry CV or one that hasn't been seated properly, loose bearing on a half shaft or something like that. Also one end is only held on with a circlip & I would imagine that could be bought separate to the actual shaft assembly and could save mega bucks if that can be done.
    Alan S
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Knock me drive shafts and shiver me timbers! AAiiii me matey...
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    Hey studdster.
    Yeah that'll be the shafts.
    I fitted reco shafts to a 306 for not much. $150 maybe plus fitting. Call European auto imports in Box Hill and see if they have any. Will cost stax more, let alone if they are Genuine Peugeot..... Ya wouldn't even think about them.
    Nov 2002
    Yarrabilba, Queensland
    2,755
    Quote Originally Posted by DJ-Studd
    Ta
    -- DJ
    Hey DJ,
    Are they interchangable form right to left?? you could swap em, then they'd only knock in faaast reverse....
    jus kiddin'
    12,256
    how are they reconditioned ?
    do they put new CV's on the shafts ?
    CV's as a rule are made up of 3 parts
    spider
    cage
    balls
    these are all matched items and wear at the same rate through a given CV so you can't really replace one item with the others
    this has always had me intrigued an no one has ever given me a definate answer
    1 x '98 306 GTi6
    7,448
    spider
    cage
    balls
    Early 205 (or 1.6L GTi) shafts are pretty ugly, and don't have cage/balls etc. like the late model (or 1.9L GTi) shafts. I'd be taking the opportunity to upgrade rather than repair.
    Mar 2003
    1,335
    AAAiiiiiiiiiii matey..... is it coming from the port or starboard side matey....aaaiiiiiiiiiiiiiiiiiiiiiiiiii.....
    Apr 2003
    Victoria, Australia
    545
    Do the series 3 driveshafts go on a series 1 ('88) without a problem?
    If so, where can I get some reconditioned ones?
    -- DJ
    6,248
    spider
    cage
    balls
    I looked into this a while back. Where they actually recondition a removeable joint (rather than replace the whole joint to recondition the shaft) I found that they replace the balls with oversized ones and regrind the ball races slightly. There can be some problems with reliability, though, if the case hardening isn't very thick or the grinding isn't done accurately.
    12,256
    Quote Originally Posted by Stuey
    that would worry me
    i would prefer to have new CV's in a car
    talking from a machinery perspective and in the mining industry mainly where parts are put under a bit of strain and replaced instead of bieng refurbished in regards to parts like CV joints
    i have seen refurbished CV joints fail in a very short time in this sort of enviroment
    ok they may be under a bit more pressure but they are designed accordingly
    a CV joint in a car has to not only rotate and live up to it's name but it also has to work at greater angles than the same units in most mining machinery
    CV joints work and last fine up to a working angle of around 15deg BTW so next time you see that brumby going down the road jacked up just think of the poor CV joints working overtime in it
    with having a bit of experience with CV joints i would really shudder at the thought of someone putting larger balls in and grinding the cage back to suit (and of course the spider as well in that case)
    i have placed these "reconditioned" CV joints in cars like laser's and the like before and they haven't lasted where as placing new ones in have done the trick and out lasted the car
    if you can place new CV joints on the shaft then that is the way i would be going
    1 x '98 306 GTi6
    9,185
    that would worry me
    What I thought was driveshaft noise disappeared after I fitted the Quaife diff!
    Graham Wallis
    2000+ Brad's Avatar
    2,404
    I have had my driveshafts rebuilt. The inner RH one went and the LH was going shortly. They reground and put larger balls into them They also remanufactured the outers which had a little play in them. Not sure of the costs as they were done under warranty, however I do know that new items were about $800-900 each for the whole shaft with inner and outter CV's. These are the S16 items however which are much larger than the stock 306 and 205 ones.
