Big bore manifold in a 404
Results 1 to 2 of 2
    Jan 2012
    Gold Coast
    211
    Default Big bore manifold in a 404
    Hi I am putting a 505 square port motor in my 404 ute and would like to use the big bore manifold so I need the larger diameter 2 into one pipe that will fit a 404 ,it is very tight near the steering column .Are there any tricks or will it have to be fabricated on the ute.
    Marty
    Tadpole drew 404's Avatar
    Jul 2011
    24
    I have one on my 404 and the guy who fitted the larger engine pipe pulled the studs out and replaced them with bolts.
