ds pump not cutting out
Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By faulksy
Thread: ds pump not cutting out
    Oct 2003
    canberra
    871
    Default ds pump not cutting out
    a mates DS hydrulic pump runs continuously does not cycle intermittently like it should
    car takes ages to rise
    plenty of green fluid , no leaks anywhere ?
    does it have air in the system and need bleeding ?
    1000+ Posts Ken W's Avatar
    North Brisbane
    2,083
    Could be sucking some air in through cracks/splits in the pipe coming from the reservoir. Could also have a cracked housing in the pump so pumping effectiveness is reduced. Best thing to do is to try a known good pump in its place.
    You might get more suggestions in the Citroen Forum.
    Cheers, Ken
    Jan 2012
    237
    Sounds like the main accumulator sphere is dead. If the diaphragm has ruptured then the pump has to fill the sphere before pressure will rise in the rest of the system causing a delay in the suspension lifting. Depressurise then whole system, remove the accumulator and shake it near your ear. If you can hear fluid sloshing around inside then it’s failed. Also worth having it pressure tested while it’s off as it may just need regassing.
    GreenBlood and Armidillo like this.
