16v Exhaust problems
Results 1 to 9 of 9
    Member Tim Tech's Avatar
    Jun 2004
    Orange NSW
    36
    Icon10 16v Exhaust problems
    undefined
    16v Exhaust Systems
    Citroen Sport International was contacted throughout 1992 as to information concerning the standard exhaust system used on the Citroen BX 16v. As we all know the exhaust manifold is a work of art, but the Australian Citroen Racing Team was trying to work out why they were not able to develop more HP's when designing and testing new exhaust systems for their racing BX 16v's.
    Many attemps and long hours were waisted with experienced exhaust engineers on dyno's across sydney tyring to work out how the standard system was so good and why they were not making considerable gains in hp's
    Several different designs were tryed, such as:
    - 3 inch pipe from manifold (no cat) straight to rear of car
    - 3 inch pipe from manifold (cat) out the left side of car
    - 3 inch pipe from manifold (cat) straight to rear of car
    The head development engineer from Citroen Sport was contacted (who designed the 16v's exhaust) revealing that it took over 4.5 months of testing and design to create the perfect standard exhaust system. The secret lies in the centre pipe. This is a special progressive pipe which holds a "venturi effect" within its design. This pipe was specially designed to the exact length and diameter. The pipe is 4mm larger in diameter before the rearward 45degree bend than it is at the start of the manifold join.
    Citroen Australia was told that in NO way were they to modify or replace that pipe. Being progressive the pipe created a venturi effect sucking the gasses from the system and whilst not disturbing the engines exhaust harmonics and gas flow. They were told that they could do whatever they like to the system past the centre pipe but nothing else.
    This was done by simply welding a joiner pipe by-passing the centre crossways muffler and using the stock tailpipe and rear muffler.
    To the amazement of the crew 8kW was gained and 12Nm of torque
    This shows once again the superiority of Citroen design and engineering and why the 16v will live on as a supercar throughout the years!!!!
    Tim Tech
    7,446
    Quote Originally Posted by Tim Tech
    undefined
    16v Exhaust Systems
    Tim Tech
    You've lost me here. Are you saying they replaced the cat with a straight pipe? Or the resonator that sits behind the cat? My experience has been that the Mi16 pipe is twin skinned to reduce noise levels. Replacing the twin skinned pipe with a regular 2.25" pipe and resonator helps. Also, on Mi16's the std. exhaust was flattened considerably around the rear suspension. Replace this with a mandrel bent curve. The rear muffler needs to be a genuine 2.25", straight through, but 21" long and 6" diameter to avoid drumming. Get all this right, and you'll find the kW and Nm, with an acceptable non-ricey noise level.
    1000+ Posts parry's Avatar
    Sydney Australia
    1,326
    Pete, any recommendations for my 205, what will help it breathe a tad better?
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:54 (8v) 1:48 (16V)
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    12,256
    was it peugeot or citroen that designed this engine ??
    i know i have heard rumours that the XU10J4RS engine was a citroen engine that was shared between the GTi-6 and the Xsara but i thought the engine from the Mi-16 was a pug engine that was shared between the Mi-16 and the BX 16V
    i would imagine that both sides of the camp would have put the effort into getting whatever engine they were using to run nicely in either make and that they are one in the same company
    1 x '98 306 GTi6
    7,446
    Quote Originally Posted by parry
    You don't need any more power, but all's fair in love and war. Anything to topple the Wuillemins. Do it similar to your 205, but you'll have to use a different shape rear muffler.
    I always thought the XU9J4 was a Pug design too, with roots dating back to the turbo 205.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    The first couple of paragraphs of this kind of answers that question, but I won't give any clues as to who it was:
    http://www.citroenz.com/BX/twin.html
    Alan S
    1000+ Posts bowie's Avatar
    Aug 2002
    Sydney, Concord City, Sir.
    3,372
    nice read..
    so if the inlet and exhaust manifold are so well constructed on these vechiles.. just how do you pull more power from them..
    Aug 2002
    3,372
    sorry dont bother replying to that... read all about those lovely Cams and cats.. lol
    Fellow Frogger! sproose16v's Avatar
    263
    Dam right! Best car ever!
    1989 BX 16 Valve Mk1 - SOLD (And Missed)
    http://www.bx16v.cjb.net
    1992 R32 GTSt Skyline
