203/403 starter motor
  • 1 Post By lo203404
Thread: 203/403 starter motor
    Member tok403's Avatar
    Oct 2017
    Sapphire Beach
    97
    Default 203/403 starter motor
    Are the 203 and 403 ringgear/starter motor gog the same. My 203 starter motor has chewed its drive teeth out, its is driving a 403 ringgear. Or is the cable not pulling it far enough into engage the ring gear? Any ideas greatly appreciated I really don’t want to fit a 403 starter.
    NOW: 1960 403 Sedan 1953 203 Ute 1957 203 wagon. Ducati Monster s2r 1000
    Previous Peugeot 1 203 6+ 403 7+ 404. 4 504 4 505. 1 205
    Renault. 3. 12ís. 2. 16ís 1. 25wagon. 1. Floride
    Citroen 1gs
    Mar 2017
    australia
    49
    Yes, the starter motors most common on a 203, (Ducel 366 or Paris Rhone D10L, 9 tooth pinion) are compatible with the 403 flywheel ring gear of 110 teeth, same same 203. From your description, sounds as though it is/was not fully engaging the ring gear.
    Oct 2017
    Sapphire Beach
    97
    Quote Originally Posted by lo203404 View Post
    Yes, the starter motors most common on a 203, (Ducel 265 or Ducel 321, 9 tooth pinion) are compatible with the 403 flywheel ring gear of 110 teeth, same same 203. From your description, sounds as though it is/was not fully engaging the ring gear.
    Yes thanks it’s what I thought they are same and for what ever reason not engaging will have to ensure I pull cable all the way out.
    Citroen 1gs
    Nov 2015
    New Zealand
    23
    I have the cable pull/no solenoid system. I did had a starter done up but the contact part on top was worn so i was pulling cable out of housing to get to contact and u had to pull it hard which would eventually break cable. Sp i am just wondering what in your case would cause the drive to not throw out far enough?
    Mar 2017
    australia
    49
    Forgot to mention in previous reply, if you move the arm up 5mm - 10mm, (see white mark on cable) this usually overcomes the problem. The cable does tend to stretch somewhat over time depending on use. Other main thing, make sure the cable is kept well lubricated within the outer sheath, eye dropper with a bit of ATF works wonders. Another thing to have a squizz at if it's not keen to kick is the contacts, only hassle is motor has to come out, and into the vice on the bench for this little clean up.
    pugrambo likes this.
