16v Cylinder Head Facts
Results 1 to 17 of 17
    Member Tim Tech's Avatar
    Jun 2004
    Orange NSW
    36
    Icon10 16v Cylinder Head Facts
    Bx 16v Cylinder Head Facts
    I late December 1991 a quest by the Australian Citroen Racing Team was made to see what developments (improvements) could be made to the cylinder heads on their Citroen BX 16v Production Race Cars.
    A stock, used head with inlet and exhaust manifolds was sent to Yamaha Racing Australia for evaluation. Conducting the tests was renowned Yamaha Racing engineer Chris Dowed who has been at the head of Yamaha's GP Bike Developements for the past 10 years.
    The main objectives of these tests were to find if any performance improvements could be made to the head package whilst still using the cylinder heads stock internals (eg: cams, valves etc.) as per cams. regulations.
    The head was tested first on flow bench and also tested for Volumetric effeciency and valve duration. The head was returned with one simple comment ......"You will not find any better than that"!!
    The heads flowbench rating was 94%
    Flow restriction 11.6%
    Volumetric Efficency was 87%
    Not bad for what is supposed to be a stock, de-tuned engine for road purposes
    As we all know there have been improvements done to these cylinder heads (ie: bigger inlets etc) but these test truely show testament to Citroen's engineering expertise and knowledge!!
    Tim Tech
    P.s: Throughout the use of the XU9J4 motor within 2litre sportscar racing internationally, not one team used anything but the stock Exhaust manifold proving its excellence in design and strength
    7,446
    Quote Originally Posted by Tim Tech
    Tim Tech
    I didn't realise Citroen were responsible for the design of the XU9J4 head.
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Thanks for that Tim, that validates much of the discussion we have had here on the board about the 16 Valve heads ability in standard form.
    Keep up the good work,
    Dave
    Cal
    Cal is offline
    Moderator Cal's Avatar
    Jan 2002
    1,624
    Thanks for the thread though. Interesting indeed.
    Cal.
    1995 Mazda MX5 - 2F Race Car
    1990 Mercedes 300TE
    1990 Mercedes 230E
    1977 Jaguar XJS V12
    1971 Morris Mini 1100K
    1967 Porsche 911S
    1957 Porsche 356A Speedster Replica
    Apr 2001
    1,340
    From what i have read in the past the Xu9J4 head took 6 years to develop and is an evolution of the 205 T16 head. Dont know the accuracy of this info, i will let you know if i find otherwise.
    Dave
    Fellow Frogger! sproose16v's Avatar
    263
    I didnt have a clue either but have done some reading around and actually had my head taken off when i did the head gasket, sent it to a mate who is an engine fabricator and he said that he could really port or polish it. Well he could of but like only a tiny tiny bit. They are an anwsome head, i love good head.
    1989 BX 16 Valve Mk1 - SOLD (And Missed)
    http://www.bx16v.cjb.net
    1992 R32 GTSt Skyline
    7,446
    Quote Originally Posted by sproose16v
    The Mi16 head is so good in fact, that without the aid of a flow bench, you'll probably go backwards. I wouldn't let mine anywhere near your average head shop.
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Peter,
    I think (my) Brad may have told you & I know I actually posted the results of his head when it was tested up here by a guy who does a few of the top V8 supercars and a few of the top dragster engines that when he put it on the flow bench, it showed figures better than most V8 supercars heads after they've been put into race trim.
    They are a brilliant piece of engineering. (To quote him; who'd never seen one before.)
    Alan S
    Member senthil16V's Avatar
    malaysia
    102
    Hey guys,
    How about the XU10J4 head....does it flow as well as the Mi16 head? Will this engine be a good starting point for turbocharging?
    With Rgds,
    Senthil16V
    7,446
    Quote Originally Posted by senthil16V
    Hey guys,
    It's basically identical.
    12,256
    so how different is the 10J4RS head compared to the 10J4 head ?
    or is it just down to cam shafts ?
    1 x '98 306 GTi6
    7,446
    The RS head has 6mm valve stems rather than 7mm. There could be others, but I don't know.
    12,256
    that would just be in the guides though wouldn't it ?
    could you put the RS valves and guides into the J4 head ?
    i know looking at the parts manuals they have different camshafts but it's a bit hard to flow test the pictures on the CD's to find any differences that way
    1 x '98 306 GTi6
    malaysia
    102
    Icon14
    Guys,
    So can the XU10J4RS head be bolted onto the XU10J4 block? Does the XU10J4R flow as well as XU10J4? Are these heads interchangeable?
    So if these were same....then there should not be any problem bolting on the XU10J4R inlet manifold with XU10J4 heads?
    I thought of changing my inlet manifold to the XU10J4R manifold as i believe there is no ACAV system on this engine.....will there be problems if i do this?
    With Rgds,
    Senthil16V
    malaysia
    102
    Icon14
    Guys,
    Hey guys,
    How about the XU10J2 head....whats the flow rate for this head?what modifications can i do to increase the flow rate?
    Any suggestions?
    With Rgds,
    Senthil16V
    7,446
    Guys,
    Hey guys,
    Any suggestions?
    They flow a tad better than a worked XU9J2 head, but nothing like a 16V head.
    malaysia
    102
    Icon14
    Dear PeterT,
    What kinda of cfm are we looking at for the XU10J2 head?
    How about the inlet manifold (XU10J4R) modification with no ACAV on the XU10J4 head? Is this possible...will there be problems if i do this?
    With Rgds,
    Senthil16V
