Aftermarket DRLs on a diesel engined car
Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By COL
  • 1 Post By 505604
Thread: Aftermarket DRLs on a diesel engined car
    Fellow Frogger! 505604's Avatar
    Junee, NSW
    753
    Icon8 Aftermarket DRLs on a diesel engined car
    Hi, wise, electronically minded people!
    I'm wanting to fit DRLs to my cars. I can easily mount the lights, but when I have talked to auto electricians, no less than 3 have shied away.
    "It's too hard.", is the complaint.
    All of them have said that the modules that can be purchased off eBay etc won't work properly with a diesel engine, and trying to wire up the lights to come on when the engine starts and then go off when the engine stops is too difficult and/or time-consuming. I couldn't afford their bill (without them telling me how much it would cost).
    So, what's so difficult about it? Why wouldn't the ready-made modules work with a diesel engine?
    Thanks in advance,
    Andrew
    Current cars: Peugeot 307 HDi Touring; Peugeot 306 Cabriolet; Peugeot 406 HDi, Peugeot 505 Familiale
    Previous cars: 1965 Peugeot 404; 1972 Renault 16TS; 1970 Peugeo 504 1800; 1978 Peugeot 504 GL; 1976 Peugeot 504 LTI; 1984 Peugeot 505 Familiale; 1982 Peugeot 604 (converted to TD) 1999 Peugeot 306 Cabriolet
    Jul 2013
    Newcastle/ central coast
    2,094
    Default Aftermarket DRLs on a diesel engined car
    What sort of car I donít really get what they are avoiding you can just turn lights on always in the bsi
    Unless they are avoiding PWM systems that pulse the lighting power when the engine is running to regulate voltage from 308 / c4 on
    4008
    Gone but not forgotten C5 x7 3008 206 GTI 180 306 XR SED 405 MI16 x2 xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    Garage C5 X7 4008
    1000+ Posts Fordman's Avatar
    May 2004
    Perth/West Australia
    1,429
    I am looking at doing similar, but have petrol engine.
    Whats' wrong with KOLO (Key on, lights on)?
    Simple relay turning on separate DRL's (presumably LEDs) with Ignition ON. I have heard that people have them turn OFF when headlights are turned on, which also doesn't sound too hard to arrange through the relay (or a separate relay), but why not leave them on?
    I have read (unconfirmed) they need to be less than 1200 candela to avoid being foglights or driving lights. Proper DRL lights should comply, I see Hella, Narva and Philips do them.
    May be other legal issues.
    I had them in my ex-Telstra BA Falcon wagon, they were using the low beam headlights, with a special module integrated into the headlight system. I found my headlight globes didn't last too long, even with Long Life globes, and when the module failed, I disconnected it. I would now use separate LED DRLs in the Territory.
    Cheers.
    2004 Scenic I 2.0 auto (Hers)
    2016 Ford Territory (His)
    2004 WRX (Sunday car)
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    4,135
    I have installed DRL's on my 2002 Renault Laguna. My car is a petrol engine, but I can't see it being to hard for a diesel.
    I hooked the lights up to the fuel pump relay and also through a NC relay which is turned off when the low beam lights come on.
    Here is a link from Hella about DRL's
    https://www.hella.com/techworld/au/T...g-lights-740/#
    Fordman and 1972Ren like this.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Junee, NSW
    753
    Quote Originally Posted by dmccurtayne View Post
    What sort of car I don’t really get what they are avoiding you can just turn lights on always in the bsi
    I haven’t even started talking to any of them about the 307!
    They’re complaining about the 406, and that’s got virtually no electronics by comparison.
    What’s the PWM?
    I did get some information once from an auto electrician who was working for a Peugeot dealer in England about the 307 and DRLs.
    A very small number of 307s in the UK had "dim-dip" headlights, but following objections from the UK vehicle approval authority Peugeot had to drop that feature.
    Subsequently they introduced a form of day running lights which were controlled by the cars electronic control unit and the rain sensor mounted near the rear view mirror. There are no physically different light units to achieve this, it is all done by programming the control unit.
    But no dealer I’ve spoken to in Australia knows about this and neither do they want to find out about it and turn them on for me. They cite the rules about not using fog lights during normal weather driving as their reason.
    Junee, NSW
    753
    Quote Originally Posted by Fordman View Post
    Not legal in NSW, unless they came from the factory like that!
    Seriously, there are rules which are okay for cars from the factory, but if you have these things fitted aftermarket, they are illegal. Certain darkness of window tinting is just one of those things.
    Fordman likes this.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    547
    Quote Originally Posted by 505604 View Post
    The question has being answered by dmccurtayne in post #2 , long term Psa sevice tech . Just hook them up to the BSI .
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    8,946
    What’s the PWM?
    Pulse width modulation for regulation. See, eg, https://en.wikipedia.org/wiki/Pulse-width_modulation
    Junee, NSW
    753
    Quote Originally Posted by Rally View Post
    Oops.
    I should not have been posting last night. I knew that I wasn’t fully awake. I had meant to ask Dave for more information about that when I quoted it. But I think that you have partly answered my question.
    But I’m still not sure what the PWM is.
    Jul 2013
    2,094
    Pulse width modulation basically switches the power to a load to maintain a certain voltage an easy way to see if a car has this is the headlight will have battery voltage when engine not running then when the engine starts the voltage can drop to 12.5 odd volts . So on and off multiple times a second so what happens is if you attach a module / relay to control led /hid lights the relay can fail early or not turn on at all due to the uneven power supply.
    4008
    Garage C5 X7 4008
    Feb 2018
    Australia
    682
    Personally, I think Col's suggestion is the way to go.
    Or just drive with your headlights on all the time. That's what I've been doing for my entire driving career. If visibility is the objective, then your headlights are better than DRLs. Especially when driving on highways out near Junee. Plus you will never end up driving around with no headlights on at night, as I see so many doing.
    Andy
    Junee, NSW
    753
    Quote Originally Posted by 1972Ren View Post
    Andy
    Thanks for your thoughts, Andy.
    I don’t know what to think about your suggestion about driving all the time with low beam headlights. Did you (or did anyone) read the Hella link about the comparison between low beam lights and DRLs?
    They make the case against low beam lights quoting increased fuel consumption figures. Yes, I was surprised, not that it would cause an increase, but the amount of that increase.
    What is it about the Junee area that you think will be a better fit for headlights rather than DRLs?
    Andrew
