RT6 head unit swap
    Fellow Frogger! fnqvmuch's Avatar
    port douglas
    975
    Default RT6 head unit swap
    I think my "radio" was used in a few cars - C5s, 5008s - by PSA at the time.
    Is it possible to simply replace an unrepairably defective one with another or is/are there coded lock/s that will prevent this?
    It would seem to be a nexus for a lot of a picasso's functionality ...
    thanks in advance,
    Steven
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
    Aug 2016
    Sunshine Coast, QLD
    889
    All the stereo head units are coded but someone with PP2000 should be able ti code the correct VIN to a replacement.
    Or drive around with the annoying beep
    Jul 2013
    Newcastle/ central coast
    1,938
    Yes you will need to code the vin number and change any configuration that is different from your car to the new unit do you have the unit yet just be aware that some units are not all compatible due to amplifier setups etc
    You will need a diagbox because a pp will not have the option to do a rt6 also sometimes rt6 and smeg units need to be remote coded ( with the diagbox online) you can get around this by changing the vin in the bsi it won’t effect anything else on a early pic.
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Garage C5 X7 4008
    port douglas
    975
    And thanks again. David, I have started a pm to you.
