306 S16 Changing break pads
Results 1 to 10 of 10
    Member jumpin_pug's Avatar
    Sep 2003
    Melbourne, Australia
    104
    Default 306 S16 Changing brake pads
    Does anyone have the service manual for the 306 S16? If so I'm calling on a HUGE favour...could someone please scan the relevant pages out of the servce manual for changing the front brake pads...descriptions of how to go about this task are more than welcome but I'd prefer pictures/diagrams hence the pages out of the service manual...cheers
    FOR SALE 1995 PEUGEOT 306S16
    Sep 2003
    104
    bump!
    12,256
    i'm pretty sure Brad wrote up something about doing his a while ago
    either do a search for user brad and brakes i'm sure you will find it
    let us know how you get on
    1 x '98 306 GTi6
    Sep 2003
    104
    brakes...i feel like a bit of a spelling it breaks . Oh well!! thanks pugrambo will check it out...now wonder my searches were turning up nothing!!! still if anyone is willing to scan the pages out of the service manual I'll be a man!!
    cheers
    Fellow Frogger! MondeoST24's Avatar
    Apr 2004
    121
    Jai, from memory it was fairly easy to do on my S16. Usually all you have to do is undo one of the calliper mounting bolts and then pivot the calliper up to remove the pads (worse case you'll have to undo both bolts to remove / fit pads). Use a G clamp to push back in the piston (make sure your brake fluid reservoir isn't full or else you'll get brake fluid everywhere as you push the pistons in.)
    The rears are a PITA, I remember I cross threaded the calliper bolt into the alloy bracket and had to retap the hole.......
    David
    Former 306 S16 owner- now own a Mondeo ST24 V6
    Sep 2003
    104
    Quote Originally Posted by MondeoST24
    I'm only doing the front for the moment. I assumed it was the same for most disc brake set-ups it was only that I had a niggling thought in my mind from a previous thread (that I can' find) that there was something intrinsic about the 306,,alas I'm probably dreaming!!
    I didn't have any problems (in that it was exactly the same as you describe) in doing my old accord so I think I should be fine.
    Thanks for the point in the right direction. Now I have to look through the threads (and I'm taking suggestions) as to what pads to put on...
    Apr 2004
    121
    I ran Mintex M1144 with Brembo crossdrilled discs in my S16. They weren't too flash when cold and gave that super tourer metallic squeal when braking. When warm they were great.
    I've swapped to EBC Greenstuff pads for the Mondeo. For everyday driving I reckon they're better- they work from cold, they're silent and there's no dust on the alloys. They also pull the car up quickly with minimal pedal effort.
    David
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    I thought a break pad was for rap dancers on the street !
    Does this look like anybody ???
    - XTC206 -
    Serious note ... fronts are usually easy ... one caliper bolt ... slide up .. remove pad, try to refit, depress piston slightly if needed. Some pads have clips on them, some have metal shimmed backs, and a dob of hi-temp blue flexible gasket goo can help stop any vibrations (which can lead to squeal). The rears. mmmmm don't normally touch them.
    Now this is a .sig
    Sep 2003
    104
    Quote Originally Posted by XTC206
    - XTC206 -
    Sep 2003
    104
    i went with the ebc oem replacement pads which i bought through autospeed.com.au. Put them on today...no hassles...the current disks were still good so I held off getting new ones..I will post back when the pads have worn in and I can properly assess the performance.
