BA10/4 Gearbox
Thread: BA10/4 Gearbox
    203
    203 is offline
    ballina
    96
    Default BA10/4 Gearbox
    I have a BA10/4 gearbox from a 604 that I am trying to dismantle/check.
    According to the manual the extension housing can be removed after removing the speedo drive gear and engaging neutral.
    My problem is that the box is stuck in third gear. I have resorted to more brute force than I am comfortable with but still no luck.
    Any thoughts appreciated.
    Norm
    1000+ Posts Beano's Avatar
    3,091
    Aren't they a 5 speed box ? There was the BA7 4 speed, the BA7 5 speed, and the BA10 5 speed.
    Dunno....I'm not an expert, but someone more knowledgeable will be along shortly.
    All I can say is that they were known for doing this occasionally, and the last I heard was that it was understood why.
    Aren't they used in other makes of car ? Jeep, I think. Some of those guys may well know, and you could find out online.
    Dec 2002
    2,537
    BA10/4 certainly did exist, but wasn't sold in anything in Australia. Probably the best RWD gearbox though. Strong and still shifted nicely, unlike the BA10/5.
    In the past I have had a similar problem with a BA7/4, which is the same basic design. I think the solution that I eventually came up with was to grind the weld off the selector arm that came off the bottom of the gearbox and remove the arm, so that the pinion that engaged the selector forks could rotate further and disengage from the stuck fork. After replacing the broken synchro ring that was causing the problem, I welded the selector arm on again.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    203
    203 is offline
    ballina
    96
    Beano The first 604's came with the BA 10 Gearbox. When the ratios were revised it became the BA 10/4 and later when 5th was added it became the BA 10/5.
    Scotty Thanks for the info - I suspected it may be a synchro problem. Will remove the lever and report back.
    1000+ Posts Dano's Avatar
    Apr 2012
    1,130
    Back in 1976, the old man privately imported a new 604 manual. It had the BA10 4 speed box. Great car, until it fall apart with rust. It came with the factory optioned poverty pack. No air-conditioning, valour seats and no rear seat belts. Pretty sure it didn't have a radio either.
