1.9 Mi16 clutches
Results 1 to 7 of 7
    9,410
    Default 1.9 Mi16 clutches
    I have got the 309 going very well but have reached the limit of the clutch, two have failed due to slipping in the past year. Very unhappy, we DNFd the Eureka ARC round last Saturday in the first 200 metres.
    First one was Borg and Beck second was Sachs. Flywheel had the correct step. Neither were impressive even when new, lack of bite. I think a Valeo one may fix the problem, the small 8 valve one in the 205 has heaps of bite. Next step up would a pull clutch from S2 or maybe go the whole way and fit a paddle clutch. Any ideas?
    7,527
    I've had good success with Valeo. Parry is now using Helix however after destroying a few. That would probably suit your needs best.
    https://helixautosport.com/catalogue...ceClutches.pdf
    9,410
    Thanks Peter, do you know if Parry has the competition pressure plate? Is the pedal pressure higher?
    1000+ Posts parry's Avatar
    Sydney Australia
    1,333
    Yes I do, yes it is a little on or off and firmer. But it is matched with a 4 puck sprung clutch. Its easy to use though, not too heavy for me.
    90 205 Gti Cherry Red(Track Car)
    2009 207gti
    1985 505gti (Shitbox Rally) Sold
    PBs:
    Oran Park: 1:27:9
    Wakefield: 1:05.6 (July 2015)
    Eastern Creek: 1:47 (16V) 2019
    Mt Huntley: 34.44 (2004 stock 205)
    Ringwood: 35.06 (30/10/2005)
    Winton: 1:33.6 (2017)
    9,410
    Thanks Parry, so a Helix pressure plate 60-4802 plus something different for driven plate?
    995
    Looking at the spec list, the 76 series drive plates appear to be what Parry is describing, as shown in the race/rally line.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, AT Power Dry Sump, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Custom Radiator and Oil cooler, 3J Plate LSD, E85.
    Sandown - 1:31.5, Winton - 1:40.2, Wakefield - 1:11.05, Phillip Island - 1:55.9, The Bend (International) 2:23.2
    Fellow Frogger! Brett's Avatar
    Nov 2001
    618
    ACS did a sintered clutch kit to suit the 206 cheaper than an import, but I haven't run the car yet
    Bathurst______2 57.22 Sandown_____1 35.29 The Bend Int__2 21.96
    Mallala_______1 22.90 Phillip Island__1 56.41 The Bend GT __3.58.12
    Winton_______1.43.90 Collingrove_____38.08
    https://www.facebook.com/FrogstompRacing/
    http://www.harlandeng.com.au
