205 GTI Front ARB
Results 1 to 7 of 7
    Jul 2014
    Sunshine Coast
    124
    Default 205 GTI Front ARB
    During investigation of the turning problem I am currently having with my 205, I have noticed that the ARB (standard) how would I go about it? is touching the Lower Control Arm on the right hand side. I have taken measurements from the centre of the bottom of the ball joint to the centre of the sway bare hole ( where the drop link attaches) and have noticed the following. RHS 175 mm LHS 150 mm another Car I have here is 160mm and 150 mm respectively.
    I was wondering what are the measurements on other GTI out there.
    Also if I wanted to correct the problem how would I go about it. Comments please
    7,557
    It should be centred by a knob on the bar, which matches the centre of the the LH body mount bush, from memory.
    9,474
    Yes, you need to have orange and blue bushes and fitted to the correct sides, so the knob on the bar fits inside the bush with an expanded area.
    Jul 2014
    Sunshine Coast
    124
    Thanks Peter & Graham I have ordered new bushes Will check again once fitted.
    Jul 2014
    Sunshine Coast
    124
    It appears I have 2 blue ones!
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    Have a look inside the bushes you may have a locating groove in both, otherwise grind or cut one in. (I did).
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jul 2014
    Sunshine Coast
    124
    The blue one on the LHS did have a groove but too far to the right instead of centre. I have replace both with a new set. ARB is now located more centrally. Thanks for all your comments
