Removing inner race 306 rear bearing
Results 1 to 20 of 20
Thread: Removing inner race 306 rear bearing
    9,467
    Default Removing inner race 306 rear bearing
    Has anyone managed to find a puller fine enough to pull the inner race of a 306 rear hub bearing? Very little space because of a round plate sitting behind the bearing.
    I have tried a cold chisel on the surface and can get pretty good purchase with a pry bar but no luck so far. Maybe heat with a butane torch?
    9,319
    I have had very good results in tight spots with a dremel if that is feasible in your situation. It is now my first port of call if I need to remove something I don't want to keep. You need a steady hand and a few of the thin cut off discs, but if you put a decent groove through the race, it will eventually split and you don't risk damaging anything.
    Heating stuff would be my last resort because I suspect the arms are cast steel, and they don't behave well when heated.
    That said, a knife edge with a tough beam bearing puller sounds like it may do the job. Mine is a Repco and works very well. Total Tools have a few sizes available too.
    ACHTUNG ALLES LOOKENPEEPERS
    9,279
    Extraire la cage intérieure (5) du roulement ŕ l'aide de l'extracteur [3]
    - Si nécessaire, déposer l'entretoise (6).
    Impératif : Toute marque de démontage sur le plan d'appui de joint de l'entretoise implique son remplacement.
    - Le moyeu roulement est un ensemble indissociable .
    19,216
    Depending on the ID , I've had success with a dyna bolt held with vice grips during tightening.
    Sometimes you can wriggle the bearing out. Other times you need to use spacers and washers and use the dyna bolt thread as puller.
    When repairing motion picture projectors I always carried a selection of dyna bolts in my tool kit.
    9,467
    Yep, that's what I need.
    9,467
    Thanks, I was thinking that was a possibility.
    9,467
    Just the inner race, the balls and outer came out with the hub.
    7,552
    Just warm it up with the oxy-acetylene torch. It will slide off easily. Butane isn't good enough. You need to heat the race up quickly.
    9,467
    Thanks for letting me know that butane isn't good enough
    Got the oxy torch still but couldn't afford the bottles. May try the dremel I think.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,467
    Run a quick tack weld on the ring about 10mm long. Should slide off easily like Peter says.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    NSW
    634
    Is the arm off the car?
    If so push the stub axle out of the arm with the press.
    Adrian Wuillemin
    9,467
    Quote Originally Posted by BIGRR View Post
    No electric welder either, usually get things done elsewhere but the car is on my hoist.
    9,467
    Quote Originally Posted by Adrian Wuillemi View Post
    On the car and I don't like the idea of taking the stub axle in and out, could become loose with the rough roads this car is used on.
    1000+ Posts pgti6's Avatar
    May 2001
    1,654
    Graham, you can borrow my elec welder if it helps.
    405 Mi16 2.2 litre race car up for sale soon. For details contact me on 0438 106 430.
    Lap times- Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    9,467
    Thanks Jeff, sounds like a good idea, later today?
    May 2001
    1,654
    Yep, any time after 3pm.
    Previous Frenchies-
    1988 205 Gti
    1998 306 GTi6
    1997 306 N5 sedan
    Aug 2011
    Břmlo, Norway
    83
    Grind the inner race with a flap disc or similar in the angle grinder. It will crack well before you get to the axle.
    9,467
    Tried the arc welder, thanks Jeff, but with no luck. In the end the Dremel got it.
    9,319
    That Peugeot tool seasink linked is just a single trick knife edge puller. I have always wanted one and when I got mine I never looked back. Invest in one, you won't regret it. The dremel is fine, but slow and if you can squeeze the puller in, it saves a lot of time. Not to mention you don't always have the luxury of being able to dispose of the offending bearing.
    9,467
    Yes, that was my original question.
