Ingnition wiring
    3,572
    Default Ingnition wiring
    Hi guys can someone help with my ignition switch wiring Attachment 114563Attachment 114562
    18,719
    You are one third of the way there already.
    Obviously the terminal marked "bat(tery) +" is exactly that.
    One of the remaining two is "ignition position" (to ignition coil).
    The one remaining is likely Accessories position ( to non ignition circuits).
    If you post the descriptions and numbers on the switch I may be able to help further.
    Otherwise meter the switch out with an ohmmeter or a test lamp.
    If the switch has a spring return position that will be for the starter solenoid and it won't have an "accessories position".
    Sep 2003
    North Parramatta
    3,988
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    18,719
    Wiring diagram: https://www.dropbox.com/sh/3jighquuq...s6EV7gDPa?dl=0
    Match the wire numbers to numbers on the switch
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,398
    Bad Bertie
    See attached:
    https://www.peugeot404vereniging.nl/...5%20Einde.pdfd
    Check the wire numbers and connect as in 12-4.
    Note: Get a magnifying glass and check the numbers on the back of your switch, you will find that the Batt + terminal is 30, the double terminal is 15 & B and the single terminal is 50.
    Good Luck.
    I think Red and Yellow wires should be connected to Batt + 30 terminal.
    B or 15 terminal connects to the wire from Coil, wire 32.
    50 terminal connects to Starter solenoid wire, wire 46.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
