Electronic speed sensor output and pinout.
Results 1 to 8 of 8
    Jan 2011
    Traralgon
    645
    Default Electronic speed sensor output and pinout.
    I have a recollection that this topic had been discussed before but I cannot find the thread. Can someone share the detail again? Looking to get a speed reference onto a new dash from the original gearbox speed sensor, 306, BE3/5 etc.
    racing 405
    1:59:09 last time at Phillip Island - less than standard Mi16.
    7,426
    I've got one, but what's the question?
    Jan 2011
    Traralgon
    645
    Question is, what does the signal from the speed sensor look like so I can configure the input correctly.
    Jan 2011
    Traralgon
    645
    Found it.
    7,426
    Please share. I was going to put one in the lathe and hook up an oscilloscope.
    18,719
    If it's to the standard of most industrial sensors the output will be an open collector NPN transistor.
    Ie Switches low whilst sensing .
    7,426
    Yes, but how many pulses per revolution is the real question.
    18,719
    Battery drill or lathe to ascertain that and a DSO as you suggested.
    As least you now a pull up resistor will be needed. (unless it is an inductive pick up)
