Citroen BX front brake pads and discs -Pug substitute?
Results 1 to 13 of 13
    63
    Default Citroen BX front brake pads and discs -Pug substitute?
    Need new ones, is there also a Peugeot equivalent/replacement for the above?
    Car is 1989 BX 19 Tri
    RegarDS
    Lou
    Oct 2011
    Sunshine Coast, Australia
    49
    Apparently 305s and 405s if yours is not ventilated (gti).
    https://rover.ebay.com/rover/0/0/0?m...2F264335924907
    Sent from my SM-G920I using Tapatalk
    8,589
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    536
    From memorey 405 Mi16 disc are the same but the pads are different .
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    9,137
    My TRi had non vented front discs. The only FWD Peugeot I can think of without ventilated discs is the 205 Si.
    63
    Front pads are hen's teeth.The tyrannies of time and distance were overcome allowing me to call upon EAI - no stock.
    But, did suggest that Peugeot 205 rear pads are the same shape though thinner. I took them.
    So for those who are stuck in the future - get hold of P205 rears as (temporary) replacement.
    Cheers and thanks to all who replied.
    RegarDS
    Lou
    63
    Corerction: P206 or P306 rears (as stated on the box)are suitable replacement for "temporary" purposes.
    Now, have had a go but came up against 5headed bolts holding the caliper. And the piston does not retract- is there a trick? Should the engine be turning over?
    Tks
    Lou
    9,137
    Heard yesterday about these 5 headed bolts on a 205! Tool shop should have a socket for these?
    18,719
    If it were my vehicle odd ball fasteners would be a guaranteed deletion.
    And be replaced with a suitable hex head bolt or an unbrako hex socket bolt.
    8,589
    9,137
    Quote Originally Posted by Loudel View Post
    Tks
    Lou
    Would 405 brakes fit?
    8,589
    63
    Job done, and what a cinch it turned out to be.
    A great thankyou to all for your suggestions/pics.
    RegarDS
    Lou
