Nankang tyres, 16TS
Like Tree2Likes
  • 2 Post By 4cvg
Thread: Nankang tyres, 16TS
    Dec 2010
    375
    Default Nankang tyres, 16TS
    I know there are a few different threads in sizes if tyres for r16 and know many of us have looked a nankang tyres for our R16s.
    Iím preparing to put a Renault 16ts on the road in a couple of months if all goes well and was having a look at different options in 155/80 R14. Decided on a set of nankang cx668 as they had good reviews and seemed to be the best choice in the size. Anyway, a few days ago I was a a tyre shop for something else and asked if they could get nankang sun that size.. to start with they asked me to go to a different size, I said that that wasnít the option I was after. The guy working there made a couple of calls and told me he could get that size in nankang. He said they were nankang ďa1Ē rather than cx668.. I asked if he ment ďas1Ē which Iíd also seen good reviews of as asymmetrical tyre but was sure they werenít available in that size. Iím sure he said yes, so I ordered a set. Today I picked them up and they turned out to be nankang ďna1Ē. I paid for them andloaded them into my Ute (havenít had them fitted). Anyway, looking at the invoice I see theyíre listed as cx668 on the bill.
    Iím looking at reviews and they seem to be a tyre more noted for longevity more than handeling and havenít seen overwhelmingly good things said about their wet weather performance.
    Iím wondering, has anybody fitted na1ís to their r16? How are they? Do I try to swap them for cx668s or give them a go? The car is getting a moderate going over with full siuspension rebuild and upgraded motor. I donít think Iíll be happy to put a tyre on it that will compromise the way it should corner. Where I live Iím surrounded by twisty roads and will see a bit of wet weather usage.
    Any thoughts on tyres appreciated.
    Feb 2005
    rosevale/tasmania
    2,702
    First, I suggest that the CX 668 is to be avoided if wet grip is of the slightest interest.
    The NA1 in a much newer design & I know of no tests of it except a Choice one (I have no access to this but some kind AF member who is also a Choice member might hunt it out on the web & summarise for us).
    But: Nankang rate poorly for wet grip across their range & any tyre optimised for fuel efficiency & longevity (as Nankang states the NA1 to be) has traded off wet grip to achieve that. So, I'd have avoided it.
    That pessimism aside, you now have them &, once they're settled a bit (a few hundred kilometres), it would be of interest were you to report your impressions. A deserted wet roundabout is a great place to explore wet grip & limit behaviour (including reaction to lift-off) as there's room for things to get a bit untidy. You'd be asking yourself: 'is this how I want my tyres behaving in an emergency?'. I predict that you won't be favourably impressed but it'd be good to see what you say. Note that different tyre types behave differently on the same pressures & you might have to play with front/rear pressure relativities to optimise handling balance to how you want it.
    If it's not total rubbish like the CX668, then other froggers might be interested in that because it's available in a number of sizes of interest (like 135/80-15 for rear-engined Renaults).
    155/80-14 is an awkward size now & nothing good is available in Australia (I include "Classic" Michelins as ungood).
    You seem wedded to 155/80-14 for some reason but those more flexible in size options have one splendid wet tyre choice available in two relevant sizes.
    The tyre is Continental's PremiumContact 2. The sizes are 175/70 & 165/70. (There are other good tyres available in these sizes but I can't imagine what criteria of choice would lead one to preferring them except cheapness.)
    The PC2 has some merits of note.
    Although a "Premium" class tyre & not harsh, it's crisp in response & handling balance can easily be adjusted by changing tyre pressure relativities front to rear (tyres with more unstable shoulders are not as responsive to pressure tuning).
    It's limit behaviour is benign (behaviour is signalled clearly & responses to remedial action are obedient).
    By a largish margin, it has more grip in the wet (laterally & under braking) than any other alternative in a size to suit 4.5 x 14 rims.
    The main demerits are that it is pricier than most (aroound $140) & isn't long lasting (but most classic car tyres reach their "use by" date before wearing out, so . . .).
    I have used multiple sets of 165/70-14 PC2s as fronts on my rear-engined Renaults & all round on my Djet. It's a lovely tyre.
    175/70 is the same circumference as 155/80 & thus gearing & speedo reading won't be affected. Despite what one might think, the steering won't be heavier (explanation on request & confirmed by 20+ years of use of 175/70-13, 165/75 165/80 & 155/80 on two Renault R12s).
    165/70 is a bit cheaper, lighter at parking speeds & the slightly shorter sidewall is crisper at an given tyre pressure.
    One good way to better balance R16 handling is to run wider fronts than rears (along with some tyre pressure tuning but with less f/r difference needed). I did this years ago with my two R12s & my Moke to good effect.
    I have fond memories of fanging one of the first R16TSs in the late 60s & I think that the best handling balance results would come from 175/70 fronts & 165/70 rears.
    ymmv
    cheers! Peter
    Dano and angru like this.
    Feb 2005
    rosevale/tasmania
    2,702
    Just one procedural suggestion: as the Renault forum has more traffic than this one, you could profitably either duplicate your post there or have a meta-post pointing to this thread.
    Mar 2013
    olinda victoria australia
    671
    You have an annoying habit of being right. Not sure that link will work if not a member.
    https://www.choice.com.au/transport/...r-tyre-reviews
    In case link doesn't work Choice gave it a score of 72%
    Wet braking 55%
    Wet cornering 45%
    Dry braking 90%
    Dry cornering 95%
    So it sounds like it could be a real surprise package once the weather changes
    Not really worthy of a car of the quality and dynamics of an R16
    Best Wishes
    Andrew
    Dec 2010
    375
    Thank you Peter for such a detailed post, really appreciate the knowledge you have on this subject! I should have probably asked before I purchased them, but wasn’t intending to purchase the day I did.. I was swayed by the thought that they were going to be AS1’s.
    The car is at least a couple of months from being ready for the road, and I shouldn’t have rushed into this. I’ll fit them and see how they go unless I hear anything particularly negative about them..
    I wonder, how would they go if I used 2 155/80 14 nA1s on the back and 165/70 PC2s on the front... could use2 on the car I bought these for and 2 on the rear of my other 16.
    Feb 2005
    rosevale/tasmania
    2,702
    The mix would be an interesting experiment. The main thing with an R16 is to anchor the front & crappier rear tyres would be a way of getting better throttle adjustability. The most important thing to experiment with would be trying to avoid lift-off snappiness at the rear in the wet. Still, better that than terminal front end plough - at least one has steering, not just throttle &/or brakes, to input remediation.
    I'd have a go if the 4 NA1s prove too easy to overwhelm at the front in the wet. Sudden radius tightening mid-corner is a good way to stress front tyre grip when one's playing.
    But why not fit the 4 new Nankangs & wheels to the other R16 & experiment with that so that you get the kms in while it's wet?
    The AS1 is hardly brilliant but isn't total rubbish & I've been recommending it in 145/65 as the best of a bad bunch for 4x15 wheels on rear-engined Renaults. I know of only one test & it comes last but I found the detail of the comparative results rather comforting & shudder to think how a CX668 (or NA1) would has fared. See:
    2019 Auto Zeitung Summer Tyre Test - Tyre Reviews
    Thanks for the test results Andrew. Choice tests are very limited in what they do & report but when they're all one has . . . .
