205 Fueling
Results 1 to 8 of 8
Thread: 205 Fueling
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    Default 205 Fueling
    205 owners as u know the fuel flows from the tank to the fuel can in a 205. Then it flows through the fuel rail and then through the fuel pressure reg..... after the fuel reg there's a fuel line that runs back towards the fire wall and disapears under it.....
    Where does it run too? back to the tank?
    7,446
    Quote Originally Posted by Luca
    It's the return line back to tank, at atmospheric pressure.
    Mar 2003
    1,335
    Peter I've thought about it and I've gone down stairs and looked at it and it doesn't make sense....
    The fuel reg holds the fuel in the fuel rail until it reaches 3.5 bar (aftermarket fuel reg) and then the valve opens releasing it into that tube back to the tank. Wouldn't it be running consistantly at 3.5 bar after the fuel reg and not before?
    7,446
    No, it's just like any other hydraulic circuit. Between the pump and the regulator it's 3.5 bar. Bewteen those two are the injectors. So there's always 3.5 Bar +/- manifold pressure at the injectors.
    12,256
    very true
    pressure is only created by resistance and in this case it's the regulator
    after that there is a pressure drop in the line back to the tank
    to get really pedantic there would actually be a little bit of vaccuum after the regulator
    1 x '98 306 GTi6
    Mar 2003
    1,335
    That's assuming the fuel pump is pumping fuel at 3.5 bar no?
    12,256
    pumps don't create pressure they only create flow, it's resistance that creates pressure but in saying that the pump has to be able to create enough flow
    pumps ratings in hydraulic land are rated at flow
    fuel pumps on the other hand seem to be rated at pressure which is a bit misleading as they supply a flow
    1 x '98 306 GTi6
    Mar 2003
    1,335
    Thanks guys.
