Upper cylinder cleaners
Results 1 to 14 of 14
  • 1 Post By schlitzaugen
Thread: Upper cylinder cleaners
    Armidale
    2,275
    Default Upper cylinder cleaners
    When I got my first Xantia in 2006, it seemed to be popular to de-coke piston tops etc. by pouring a teaspoon or two of brake fluid through the spark plug hole, and leaving it overnight to work it's magic before starting the car and admiring the clouds of smoke. This of course was supposed to loosen up carbon deposits and allow them to be swept out with the exhaust. I confess I did try it at the time - can't say that I was aware of any massive performance improvement, but it didn't appear to do any harm (apart from smoke affected washing).
    Is this still an approved technique? Or has it been relegated, along with tin canisters etc., to the dustbin of history? Are there downsides (could it increase bore wear, gum up exhaust valves, block the catalytic converter etc)?
    I am also intending to feed the engine a can of LiquiMoly Petrol Engine Intake Decarb. I am hoping this will clean up the air intake tract, but does it make the brake fluid redundant?
    The engine I am thinking of trying it on is a 19-year old ES9J4, that has traveled c. 170,000km.
    Alec
    10,666
    I thought that sort of thing went out in the 1950s. I'll be interested to see what people say though.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    1000+ Posts driven's Avatar
    Apr 2005
    1,386
    Probably end up losing all your compression if you have any left that is
    Armidale
    2,275
    Compression is good - 180 +- 5 psi on all 6.
    Please excuse my cracked 'glass':
    Alec
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,663
    Alec
    You obviously haven't been using enough "REDEX" Upper Cylinder Lubricant, so I'd recommend a treatment of good old "Bristol Self De-Coke"!!
    Armidale
    2,275
    Well I googled the above treatment - if this is what you meant Kim, then you're a very naughty boy!
    https://mixmag.net/read/bristol-cocaine-europe-news
    7,414
    Subaru.
    8,763
    Water injection will clean the combustion chamber and piston nicely.
    Armidillo likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    Ipswich, Queensland.
    1,872
    As Peter has alluded to, Subaru have a product that can be sprayed down a vacuum line whilst the car is running. I used this cleaner on a XU10J2 many years ago that had a massive carbon build up behind the inlet valves. I removed the injectors and cut down the sides of a toothbrush to fit in the injector hole. I sprayed the foam down the hole of a closed valve and scrubbed the back of the valve with the toothbrush. The original build up was about 6mm thick, and after 20 mins work all were clean.
    I ran the motor producing a large cloud of smoke for 5 mins, and all was well. The car did pick up some power after cleaning.
    '56 Renault 750 (16TS Power)
    '62 Renault Dauphine Gordini
    '08 Renault Megane sedan
    1,872
    Double post. Posting on a phone sometimes doesnít work so well.
    Melbourne, Aus.
    17,663
    I was thinking more of a 50's treatment in a can, maybe similar to this: Engine Carbon Clean - Home -The Ultimate 30 Minute Engine Detox
    Armidale
    2,275
    Hmmm - no harmful chemicals, allows easier breathing etc. - sounds like I should try it for my asthma!
    Alec
    7,414
    Here is the result of putting a can of Subaru cleaner through an XU10J4 which had done approx. 200 000Km. It was a lot worse than that before I had time to get the phone out.
    Armidale
    2,275
    Very impressive - looks similar to the results of the brake fluid treatment! At first I thought I could see soot particles in the smoke, but they turned out to be spots on my screen!
