Ignition for an Even Fire V6
    Fellow Frogger! OddFireV6's Avatar
    152
    Default Ignition for an Even Fire V6
    Att Graham Wallis or Graeme Lewis or any others with genuine knowledge please
    I have an even fire engine and two Garrett T28 turbos ex Nissan R32 GTR for my 505 to replace the Oddfire 2850 V6 and single TO4 turbo currently in the 505. What options do I have for an ignition system?
    Some ideas I can think of are to bore out the RH head for a conventional dizzy, use a Jaycar kit but I don't know what it would use as a crank sensor. Volvo used a sensor on the bell housing to detect a light metal ring on the flywheel.
    OddfireV6
    504 V6 24V, 203
    12,256
    Quote Originally Posted by OddFireV6
    can you use the same system as the commodore V6 with the coil packs and crank sensor
    they seem to be a tidy unit and fairly compact sitting on the front of the left hand bank
    just a thought i had a while ago if i ever went even fire
    1 x '98 306 GTi6
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    are you going EFI? If so, run an aftermarket ECU and commodore coil packs. That way, you dont need a dizzy at all!! All you need is a crank angle sensor to run the lot
    Other wise, just run the Volvo (I'm assuming its a Volvo motor) dizzy?
    152
    Haakon, Sorry I should have said I am using straight LP gas via a Gas Research carburettor so I will not have an ECU of any kind. Therefore its a dizzy only that I need.
    The Volvo dizzy will not work, only oddfire Volvos had distributors and this would obviously not work in an even fire, all the even fires used an ECU based ignition with a HT distributor on the LH head. I have thought I could use any six cylinder ditributor from an old Ford or Holden straight six but these would need to be adapted to fit.
    OddfireV6
    504 V6 24V, 203
    May 2002
    canberra...
    8,747
    Even fire Renault motors (ie late R25 V6 and R25 V6 Turbo) run a dizzy on the front of the left bank. It is just a cap and rotor, and combined with simple solid state ignition module and crank angle sensor (eg like a Fuego system) you will be in business. Now you just have to find an evenfire R25 V6 dizzy and timing chain cover
    Otherwise, you might find an aftermarket ECU for ignition only - use it with the crank angle sensor and commodore coils.
    9,177
    Quote Originally Posted by Haakon
    Alan Upton and I bought a sensor from Beninca's (Autronic dealer) and used (added) bolts on the flywheel to trigger it and the ECU.
    As long as you work out the angles you should be able to trigger a Jaycar system and then use the HT distributor to do the switching between cylinders.
    Graham Wallis
