LED HEADLIGHT Globes - Bush "Electrical" Mechanic
Results 1 to 10 of 10
Like Tree6Likes
  • 1 Post By driven
  • 1 Post By JohnW
  • 3 Post By Kenfuego
  • 1 Post By driven
Thread: LED HEADLIGHT Globes - Bush "Electrical" Mechanic
    1000+ Posts driven's Avatar
    Apr 2005
    1,385
    Default LED HEADLIGHT Globes - Bush "Electrical" Mechanic
    Need new Globes? Get those fancy LED ones and impress your Froggie mates
    Too expensive, worry not. Bush Mechanic will help today.
    Easy, get your old globe, smash out the inner bits, safety here. Save the mounting ring.
    Down to local hardware, get those great LED torches.
    Bit of Silastic, all set for that RWC.
    Beano likes this.
    8,489
    Around here it will get you into strife with a roadworthy. Leave it to the bushies.
    1000+ Posts Beano's Avatar
    2,984
    Get your old globe, smash out the inner bits.....then discover that the LED cluster is not 12 volt...
    Get another, then discover going home late that night 10 Ks from town, that there is some weird electrical incompatibility...
    Apr 2005
    1,385
    Quote Originally Posted by Beano View Post
    Look closely my grasshopper it is actually a torch fitted into the retaining ring with silastic
    See l2.jpg,last image, unfortunate our thumbnails aren't working
    Armidale
    2,273
    Just make sure that you mount the globes with the on/off switch easily accessible. Also, what happens when the batteries go flat?
    Hmm shouldn't let real world issues get in the way of a good invention!
    Alec
    Brisbane/Australia
    2,014
    Except you wouldn't get a roadworthy using those bulbs as you wouldn't have high beam and low beam.
    The photograph shows a P45T bulb base so presumably this if for a older car (70's or earlier).
    A normal P45T bulb has the low-beam filament that shine upwards so bounces off the top of the reflector and the the light is directed downwards and to the left (for RHD cars).
    The bulb in your fix, apart from not being switchable from low beam to high beam, would just direct the light straight ahead.
    So whichever way the bulb is pointing, which is probably straight ahead, that where the light beam will be directed (with some minor refraction by the light lens). Also, the torch bulb has a very narrow beam totally unsuitable for a car.
    This might work as a temporary fix if you're stranded half way across the Nullabour or some such place but no good anywhere else.
    Oct 2002
    Melbourne Victoria
    11,479
    Icon10 Progress
    Don't worry the LED conversion will happen.
    I used to sell a swag of 12 volt Lucas flat ring base globes to a guy each year at the Bendigo annual Vintage Car market, he told me he bought the globes just for the Lucas base, to smash the globes and solder in a Halogen replacement headlight globe. he was sourcing those halogen globes from Asia. Unfortunately for me his Asian supplier on learning what he was doing offered to supply a headlight globe in that configuration and undercut my price!!
    So I guess if there is a market the same Asian suppliers will build a better LED headlight globe if you will pay for one.
    Now if anyone needs some Vintage Lucas based 12 volt double contact headlight globes, I think I still have a few!!
    Ken
    10,663
    Do those Lucas bulbs come with a smoke replacement kit?
    COL likes this.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
    Oct 2002
    Melbourne Victoria
    11,479
    Icon10 Like that!
    but sounds like fake news ( I tried never to let the smoke escape from my lucas equipment) once they were sold they were out of my control John
    Ken
    COL, JohnW and driven like this.
    Apr 2005
    1,385
    Quote Originally Posted by REN TIN TIN View Post
    This is a Bush Mechanic Trick only.
    https://en.wikipedia.org/wiki/Bush_Mechanics
    Then watch the Bush Mechanic Youtube Videos
    I am only perpetuating these crazy fixes from the Bush.
    It is kinda tongue in cheek, but could get you going if stranded out on the back and beyond
    Recent Bush Mechanic posts, Valve spring and Brake piston compressors are great ideas.
    Encourage others to submit their quirky ideas
    Armidillo likes this.
