Peugeot 205 electric window weight
Results 1 to 12 of 12
    Perth
    159
    Default Peugeot 205 electric window weight
    Hi.
    I have searched for this answer, and I hope someone knows without me having to remove the motor and mechanism.
    For a Peugeot 205.
    Does anyone know the combined or part weight of?
    - electric switches (not a lot)
    - electric motor
    - window mechanism
    Is the same mechanism used if you switch to manual windows?
    If it is then I presume the decision comes down to keeping the electric windows or switching completely to plastic windows?
    Cheers.
    9,262
    What do you want to achieve? The stock setup works okay, but if yours seems sluggish, there's no need for radical measures. A good clean and lube of the mechanism, inspection of wiring and some general maintenance (cleaning switches) should see it back in action.
    If you want to get a bit more involved, I would suggest you take apart the motor and gears, clean and lube and perhaps skim the comm and replace the brushes if you can, that'll see it working as new.
    Also make sure the window doesn't cock in the rails, that kills these things.
    ACHTUNG ALLES LOOKENPEEPERS
    Perth
    159
    Hi. Thanks, good info. If I keep the electrics I will service it as you say. However, it was working very well when I parked the car up.
    I am primarily building the car for motorsport, so weight versus function is what I am chasing. I have converted a few motorsport cars to manual windows before, but with a cage the winding arm can be a pain to get to. So I am tempted to keep the electrics this time if there isn't a big difference in weight between the setups.
    But I had the door off the car the other day, and it weighs a tonne!
    Sent from my Pixel using Tapatalk
    997
    Without any data, I left electric windows in the 206. Can't reach the handle in harnesses and didn't seem like it was worth the effort.
    Plastic windows would be worth it, but not legal in many categories.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, AT Power Dry Sump, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Custom Radiator and Oil cooler, 3J Plate LSD, E85.
    Sandown - 1:31.5, Winton - 1:40.2, Wakefield - 1:11.05, Phillip Island - 1:55.9, The Bend (International) 2:23.2
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,426
    You can retro fit winders but you will need the mechanisms which we never got in OZ so youll need them from the EU/UK etc. Just leave them elec for now or go plastic if your events allow and remove all the bits.
    94 205 Gti Classic #9
    91 205 Si
    87 205 GTi Race Car
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,461
    May help.
    "Pinched from another forum" (This came from Australian 16v205 Register, this forum. Posted by parry Australian 16v205 register
    Item________________________Old Weight____New Weight_______Saving
    Driver door internals___________3_____________0_______________ 3
    Passenger door internals_______3____________0________________3
    Driver Rear 1/4 Windows_______1.7___________1________________0.7
    Passenger Rear 1/4 Windows____1.7___________1________________0.7
    Driver Windows_______________3.7___________1.4___________ ___2.3
    Passenger Windows____________3.7___________1.4______________ 2.3
    Bonnet______________________12.5__________7.9_____ _________4.6
    Slam Panel___________________1.1___________0.2_________ _____0.9
    Radiator_____________________5_____________2.6____ _________2.4
    Heater______________________11_____________0______ _________11
    Inner Door panel______________2_____________0_______________2
    Under Dash__________________11____________0_____________ __11
    Dash_______________________4______________1_______ _________3
    Battery_____________________10____________4.9_____ _________5.1
    boot_______________________17___________6.5_______ _______10.5
    Rims (SMR to OZ)___________36.4__________19.6_____________16.8
    Total_____________________126.8_________47.5______ _______79.3
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Perth
    159
    Thanks, I didn't realise we didn't get manual.
    Perth
    159
    Thanks BIGRR. So the front door internals at 3kg would be mostly the elec motor and window mechanisms. That is tempting considering I am removing everything else. But it makes the move to plastic windows nessesary
    The glass is surprisingly heavy!! I'll try and figure out the rules, but maybe the best of would be to fit plastic windows with the elec windows. Or even find an alternative lightweight mechanism. I do like a challenge.
    9,262
    One option would be to go to a cable lifting mechanism. You would have to custom build yours but I think that might save you a bit of weight. Have a look around the internets, I think you can buy universal kits. You will still have to custom install it.
    All other bits pale in comparison to the glass weight anyway so that's the ticket, but as mentioned above rules might be against you.
    That said, the weight of the power mechanism including motors in a 205GTI must be the lowest I have seen in a car. You should try a door off a BMW 2000CS for size.
    Perth
    159
    Cheers. Yes I have a spare set of cable mechanism and manual too from my previous Renault Megane. I'll have a play on the weekend to check size/fit.
    Oct 2003
    624
    Door internal parts, Winder mechanism, glass & intrusion bar come in at a collective 11kg per door
    Perth
    159
    I think I could make this work? And probably take some of the spare overhang weight out of it also.
