Jaeger 504 fuel sender fixed
Results 1 to 2 of 2
  • 1 Post By BIGRR
Thread: Jaeger 504 fuel sender fixed
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,461
    Default Jaeger 504 fuel sender fixed
    My Ti fuel gauge started fooling around about 12 moths ago. Has worked perfectly and accurately since 1973. Last time I had the Ti out the gauge dropped to dead empty and stayed there.
    So today I pulled the sender out and have rectified the problem: Corrosion on the brass power pick up ring on the float arm.
    I folded a small piece of wet and dry (4 thicknesses), slid it between the brass ring pick up surfaces, spat on it and then worked the float arm full travel 10 or 20 times. This shined up the brass surfaces.
    My fuel gauge now works perfectly again.
    Attached Thumbnails Attached Thumbnails Jaeger 504 fuel sender fixed-img_1723.jpg   Jaeger 504 fuel sender fixed-dsc09684.jpg   Jaeger 504 fuel sender fixed-dsc09685.jpg
    Beano likes this.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    1000+ Posts Peter C's Avatar
    SWOTR
    3,803
    Good info.
