405 Mi16 2L Sump Gasket Change
    Mar 2005
    perth
    132
    Default 405 Mi16 2L Sump Gasket Change
    I've noticed a small weep from my sump seal and have looked for a new gasket. I've been told from a few shops that there isn't a gasket for the sump. Can anyone suggest what is the best gasket sealant and any tips to replacing it?
    7,426
    Correct, there is no gasket when using an alloy sump. Use ThreeBond 1211. Steel sumps, ie non A/C 205, 405 etc. had gaskets.
    Mar 2005
    perth
    132
    Thanks for confirming Peter.
    Mar 2005
    perth
    132
    Hi Peter,
    Do you know what the sump bolts should be torqued up to?
    7,426
    20Nm.
    Mar 2005
    perth
    132
    20Nm.
