Diesel no start
Results 1 to 20 of 20
Like Tree3Likes
  • 1 Post By Beano
  • 2 Post By Ceenine
Thread: Diesel no start
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    456
    Default Diesel no start
    My 1.6l diesel C4 has been sitting for some months and won't start. I have plenty of herbs in the battery and diesel is present at the junction at the top las of the motor. Do I need to keep squeezing the manual pump at the top of the motor or is there some other potential issue I need to be aware of?
    Don
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,842
    You might get more suggestions on the Citroen Forum. Have you locked and unlocked the car using the remote control a few times? Also try turning the ignition off, wait 30 minutes and disconnect the battery for 30 minutes. Then reconnect, lock and unlock the car and try again.
    If those tricks don't work, you might have to start checking if the lift pump in the tank is getting power and working.
    How long is it since you ran the car or filled it up with fresh fuel? Is the diesel fuel still good or has it blocked the fuel filter?
    Cheers, Ken
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    918
    Yep pump the hell out of it also after a good pump get somebody to crank it while pumping u can lift the bulb up to make it easier
    Garage C5 X7 3008 XTE
    Gone but not forgotten 206 GTI 180 306 XR SED 405 MI16 x2 505 GR xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    Jul 2013
    918
    These are always tricky after a fuel filter replacement
    456
    Quote Originally Posted by Ken W View Post
    Cheers, Ken
    Ken
    The fuel is being pumped to the junction at the top of the motor so that point is eliminated. Is there such an animal as fresh diesel. I understand with my rudimentary knowledge of petrol that the volatiles can evaporate.
    Don
    456
    Thanks David, I will give that a try
    North Brisbane
    1,842
    Hi Don,
    Got any action yet?
    Cheers, Ken
    1000+ Posts Beano's Avatar
    2,870
    I love the smell of ether first thing in the morning
    JohnW likes this.
    North Brisbane
    1,842
    Yes Beano,
    That thought had occurred to me too. I just went down and checked my can of Start Ya Bars...d that I use regularly for the motor mower and wipper snipper and there are instructions for diesel engines although it says to disable the glow plugs.
    Cheers, Ken
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,187
    There's always Isopropyl Nitrate..........
    456
    You fellows just want to blow my motor up just for the fun of it! Actually if I can't get the gearbox going I might follow the various highly volatile suggestions. I will report back next week after I try David's less dramatic suggestion of pumping the c**p out of the rubber pump while applying ignition (?)
    Don
    2,870
    Sometimes a bit of ether just gets the whole process happening, at least for petrol engines. I confess that I know very little about diesels, but that principle still holds true.
    Please do remember to disable the glow plugs though...
    Jul 2013
    918
    You need to remember the compression and the small amount of fuel a 1.6 diesel has easy to over fuel and bend a rod last time I took a cam belt off one of these it was for aerostart
    2,870
    ^ Do you mean that the engine was trying to compress the liquid diesel fuel ? Diesel 4WDs sure are prone to engine damage from sucking in water.....but hang on a tic....you said it was caused by Aerostart.....
    Oh...I see...it was pumped full of liquid diesel, didn't start, then was made to fire by using Aerostart.
    1000+ Posts driven's Avatar
    Apr 2005
    1,283
    Better check the following 25 items then
    https://mercedessource.com/problems/...olutions-guide
    Bush Mechanic trick
    Don't get a diesel
    Jul 2013
    918
    Yeah flooded then bang lol
    Newcastle
    2,394
    Hi
    My observations of people using aerostart, in what ever crudely named tin, is they use too much. Lots too much. Certainly cracking pistons in diesels is common with using starting fluids, so I do believe dmccurtayne.
    SO BE WARNED !
    jaahn
    Jul 2013
    918
    Thatís it a little toot is fine but when it kicks they double down and pump it in there then game over
    Perth Western Australia
    2,633
    I haven't read all the previous posts but.. Could the 'water in fuel' sensor be doing it's job?
    456
    Well, finally got the ba****ard to start. I believe it must have been an airlock caused by the draining of the fuel lies over a 12 month period since I last started the car.
    Now I can get the auto electician in to try to find where the problem is in the EGS which says "permanent 12+ not connected" or somesuch. It will be a great little car once I get it going again. I purchased another 2nd hand gearbox ECU from a wrecker but that made no difference.
    JohnW and Ken W like this.
