Peugeot 206 gti 180 ecu file
    May 2011
    melbourn
    87
    Default Peugeot 206 gti 180 ecu file
    Hi All,
    Do anyone have a original ecu file?
    regards,
    Wai
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    927
    Did you update it via eobd or straight to circuit
    Garage C5 X7 3008 XTE
    Gone but not forgotten 206 GTI 180 306 XR SED 405 MI16 x2 505 GR xzara VTS 406 SV 206 XT Berlingo 2011 (best car ever) 306 HDI 307 XSE HDI touring
    Fix it right the first time
    May 2011
    melbourn
    87
    I just want VVT setting in MS3X.
    Jul 2013
    927
    Ok I backed mine up may have it somewhere was a while ago
    874
    I’m not using MS3, but my VVT is controlled using a PWM on a base frequency of 300hz, varying 30-60% duty cycle to get full 40deg on cam movement.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    May 2011
    melbourn
    87
    So what is the min and max degree?
    Peugeot 206 gti 180 ecu file-ms3x-ignition-option.jpgPeugeot 206 gti 180 ecu file-ms3x-vvt-setting.jpg
