Nyloc Nuts size
Results 1 to 12 of 12
Like Tree8Likes
  • 1 Post By bluey504
  • 3 Post By PeterT
  • 2 Post By COL
  • 2 Post By PeterT
Thread: Nyloc Nuts size
    Aug 2017
    spain
    53
    Default Nyloc Nuts size
    Can someone tell me please the thread dimensions of the six front suspension strut tower nuts on the peugeot 205 , year 1995 series 2. Cant find any info at all !. It looks like metric fine but its not a standard size ???.
    Oct 2003
    611
    M7 x 1
    1000+ Posts bluey504's Avatar
    Dandenong Vic
    1,242
    Another non-standard thread size. M7 is a Peugeot special for strut tops, the 504 uses a M7 bolt.
    Just because it exists doesn't mean you should use it.
    Brendan (Currently without facial hair!)
    PS Supporting the Movember campaign.
    Kenfuego likes this.
    8,633
    Yeah, the frenchies really like M7. Really can't understand why, but the sump is also held by hex head M7 bolts, which are a pain to do/undo with a socket and if you want socket heads (Allen) they are only available from the US of all places. M7 is also present all over the top of the engine in places like the thermostat housing, the dizzy/senders' housing and so on. What's wrong with M6?!
    ACHTUNG ALLES LOOKENPEEPERS
    1000+ Posts Kim Luck's Avatar
    Melbourne, Aus.
    17,482
    In some parts of the world where "Metric" abounds, engineers have had free reign to chose whatever size they like. Obviously 6 mm is too small and cannot sustain the same torque or it would have been used. Not rocket science really.......
    Aug 2017
    spain
    53
    Thanks for the replies, yep i agree its a bit of an odd ball , still i suppose they had their reasons for it . Now i can get to order up some new ones .
    Thanks again.
    7,386
    Mostly Aussie ignorance. My father in law's 1923 5CV has many M7x1 bolts.
    Kim Luck, geckoeng and JohnW like this.
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,835
    I agree, because M7 was so hard to get here many years ago I kept every nut and bolt out of all the French cars that I wrecked.
    Kim Luck and Kenfuego like this.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    8,633
    Quote Originally Posted by Kim Luck View Post
    Don't think so. There is absolutely no reason to use M7 bolts on a water pump or timing cover (Renault is guilty of both in 807 and the former on 810 series engines), or the dizzy housing (Peugeot), or the sump (both Renault in 807 engines and Peugeot in 205GTI). There is absolutely no force on those bolts, they just keep an aluminium housing from falling off. And so on.
    My opinion is they just wanted to use a size that wasn't that common so they could get some coin from selling fasteners as well.
    Honda (and possibly other manufacturers) use undersized heads. A M8 bolt needs a 13mm spanner in everything apart from a Honda. They use 12mm heads. Maybe it's just the Japanese industry trying to save on iron ore imports. Or maybe they saved one poofteenth of a cent on each bolt, who knows?
    Meh. It's just annoying.
    In fact the argument that you need the superior holding power is just daft for the strut tops on 205GTI. I managed to pull one of the studs off by just doing it up tight with no effort the stamped metal of the hat is so flimsy. A M6 would have done the job summa cum laudae.
    7,386
    So they planned that way back in 1923? I don't think so. You just live in a very small world.
    jaahn and geckoeng like this.
    Newcastle
    2,515
    Hi
    All Jap manufacturers standardised on head sizes before I was working on cars. They use 8, 10, 12, 14, 17 for almost every thing. Not many specials either, less now than before and less fine metric too.
    They just work in a different world to French and German cars. I am not sure about the Japanese cars made in USA which possibly might have inch heads in the Trump era
    Do Landrovers still have WW heads ?
    Jaahn
    Melbourne, Aus.
    17,482
    There are standards for metric fasteners; if yours aren't the same as these they are not ISO.
    https://en.wikipedia.org/wiki/ISO_metric_screw_thread
