Dodgy Electrical Connectors.
Results 1 to 11 of 11
Like Tree10Likes
  • 1 Post By Kenfuego
  • 1 Post By dimistyle
  • 1 Post By Exfrogger
  • 2 Post By bob
  • 4 Post By Dano
  • 1 Post By COL
Thread: Dodgy Electrical Connectors.
    Jan 2013
    Geelong
    503
    Default Dodgy Electrical Connectors.
    Is it my imagination or are these El Cheapo female spade terminals total rubbish?
    Faced with innumerable broken wires etc, I bought a heap online in anticipation of renewing as I go.
    But they appear to be a one way trip; if I have to remove them for whatever reason when I put them back, they seem to fall off if the wind changes!
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
    Quote Originally Posted by geodon View Post
    Can you show some pics of what you have, is it the wire that is fall out or is it the connector itself connector itself not staying put.
    Regards Col
    2002 Renault Laguna V6
    1973 Alpine A110
    Oct 2002
    Melbourne Victoria
    11,504
    I have always bought Narva terminals, have used boxes of them over the years without any problems - must admit I haven't bought any in recent years and I have used the insulated crush type and also Narva soldered terminals and they work well too.
    Ken
    Dano likes this.
    Aug 2016
    Sunshine Coast, QLD
    848
    I think if you buy the insulated crush type and the cheap as blue handled crimp tool they are a hopeless setup without trial and error of how much wire to strip and where and how much to crush depending on wire gauge.
    If you are doing a lot buy a decent ratchet crimper and proper terminals with slide on soft or hard protection. Usually from auto sparkies.
    Or trial and error as they are cheap😅
    driven likes this.
    Nov 2005
    Geraldton
    1,539
    Don't get me started...
    JohnW likes this.
    In the Shed(s):
    In the Past:
    bob
    bob is online now
    May 2001
    Skipton
    2,332
    G'day,
    Quote Originally Posted by Kenfuego View Post
    Ken
    Utilux on the old boxes here....
    Cars have far too many "connectors", purely for the convenience of the assembly line. You will be far better off to replace "broken" wires with a solid soldered connection. If the maintenance problems are that great that you really need to be able to regularly remove a connection, think old time and go for proper screwed connections. A tiny 4mm nut and bolt and star washer assembly is going to give you a lot a lot less grief than a high resistance spade connector hidden inside a plastic block, the usual failure point of plug in relays.
    A program of connector abolition is the way to go, get rid of all those assembly convenience devices. If it's a Fuego start with the one on the panel behind the motor, that's the one that gets hot enough to start fires, probably the inspiration for the model name....
    cheers,
    Bob
    Kenfuego and JohnW like this.
    Newcastle
    2,563
    Hi
    All the ratchet crimp tools are not made equal either. I have used expensive ones at my previous job. I purchased a Jaycar one some years ago and it was a poor crimper and I should have returned it probably. But I 'adjusted' it a bit to get it to reliably crimp the insulated terminals.
    Jaahn
    1000+ Posts driven's Avatar
    Apr 2005
    1,392
    Need to use best possible terminals for all mission critical connections..
    Fellow Frogger! Dano's Avatar
    Apr 2012
    912
    I crimped and soldered my terminals. Followed by applying shrink wrap. Time consuming yes, but in my humble opinion, a much better joint and finish.
    Buy quality terminals and crimping tool....
    dimistyle, COL, geckoeng and 1 others like this.
    Jan 2013
    Geelong
    503
    Dodgy Electrical Connectors.-img_2321.jpgDodgy Electrical Connectors.-img_2322.jpgDodgy Electrical Connectors.-img_2323.jpgDodgy Electrical Connectors.-img_2325.jpgDodgy Electrical Connectors.-img_2326.jpgDodgy Electrical Connectors.-img_2327.jpg
    The problem is the metal the terminals are made of is not "springy"
    I've shown some connections made on the 404 ute. They go on firmly the 1st time but if you have to disconnect & reconnect- as you often do on the ign. sw- they wont stay on; they just fall off.
    OTOH when I tried a Narva terminal (4th photo), it went on & off several times with no loss of "stickiness". I now have to throw out about 50 spade terminals that are worse than useless because I have to re-do the work I've done.
    The crimping etc is not an issue. I discovered decades ago good wire stripping & crimping pliers save me money on dental bills.
    1949 Citroen Big 6
    1955 MGA1500
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,933
ID:	110273Click image for larger version.
ID:	110274Click image for larger version.
ID:	110275Click image for larger version.
ID:	110276Click image for larger version.
ID:	110277Click image for larger version.
    I have found that cheap connectors will not retain their shape and loose connectivity. You can overcome this to some degree by compressing the female crimp carefully with a pair of pliers.
    Just a tip when doing your crimping, make sure that you use the correct crimp for the gauge of wire that you are using. That way you will get maximum clamping pressure on the wire.
    Dano likes this.
    Regards Col
    1973 Alpine A110
