Beware of Generic Flexible Brake/Clutch Hoses
Results 1 to 3 of 3
Like Tree5Likes
  • 3 Post By geodon
  • 2 Post By geodon
Thread: Beware of Generic Flexible Brake/Clutch Hoses
    Jan 2013
    Geelong
    437
    Default Beware of Generic Flexible Brake/Clutch Hoses
    I can't get a decent brake pedal on my Pug 404 ute project car despite everything being new/reco.
    So to investigate I used 3 vice grips to clamp off the flex hoses.
    Perfect pedal.
    I release the rear: pretty good pedal.
    I release the fronts: pedal goes to the floor.
    And now a finesse: I clamp the front hoses as close as possible to the inlet. Perfect pedal.
    I clamp at the wheel cylinder end: pedal goes to the floor.
    It's not rocket science to work out what's happening!!
    The rear hose was locally made; the fronts I bought online.
    This is the last time I trust hydraulic hoses that I don't know where they are sourced.
    jaahn, 85Fuego and Roland like this.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    Jan 2013
    Geelong
    437
    And this is not the first time I've been burnt by a cheap generic. The Pug will be easy to fix.
    My previous resto was a Series 2A Land Rover.
    It had a Holden 186 powering it. Orig LR 2.25L motors are getting scarce plus it was a Geelong conversion (Johnston Engineering late of Duoro Rd Nth Geelong) so IMHO it had merit to stay as it was.
    I took the Bosch starter to a sparky to overhaul. He sold me a brand new generic unit for half the cost of overhauling the orig.
    12 months later, I hit the starter & it spun freely. I took it out & the pinion had disintegrated. No big deal ordinarily- the teeth just fall down to the bottom of the bell housing where there is a port for cleaning. BUT in this case a tooth had jammed the ring gear against the adaptor plate.
    So, I saved $50 but I had to do engine & GB out, clutch & flywheel off and re-assemble. PLUS I bought a new Bosch unit anyway!
    The moral: avoid generics unless there is evidence they are OK to use.
    Armidillo and jaahn like this.
    1949 Citroen Big 6
    1955 MGA1500
    10,367
    I get mine made to order at one of the good brake places in Perth. They have all the Lockheed fittings I need and the hoses are perfect - and braided stainless are available and give even better results. I did try online purchases of flexible hoses but poor results - cracked externally quite quickly.
    NOS are still available but I'd emphasise "old" in the NOS. I couldn't get a decent pedal and you could feel one of the apparently good hoses expanding under pressure. I held the hose and got someone else to press the pedal - it was quite obvious that the reinforcing had failed.
    Renault 4CV 1951
    Renault R8 1965
    Renault Scenic 2005 (wife's)
    Renault Scenic 2007 (mine)
    CitroŽn CX Pallas 1980
