Peugeot 205 DKZ Head Corrosion
Results 1 to 11 of 11
    Jul 2014
    Sunshine Coast
    109
    Default Peugeot 205 DKZ Head Corrosion
    I recently removed the head off a 205 GTI engine that had been sitting around fore a while. There is quite a bit of corrosion around the water galleries, is the amount of corrosion normal for theses heads? would it be worthwhile repairing? I have attached photos for comments. My plan was to have 1mm machined off this head and fit on my DFZ engine along with the DKZ cam to improve the performance. Does any know the original thickness of a DKZ head?
    Attached Thumbnails Attached Thumbnails Peugeot 205 DKZ Head Corrosion-img_1232.jpg   Peugeot 205 DKZ Head Corrosion-img_1233.jpg
    7,344
    That head is repairable but it will be cheaper to find another head from an Si or DKZ.
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,024
    If your DFZ head is good you could work with that.
    8,431
    Wow. I would consider that head gone. Have a look at the pitting in the enlarged photo. Right next to the coolant gallery there is a deep one, which is not going to be cleaned by shaving 1mm. If you have a new head gasket have a look where the sealing bead of blue material is positioned and I think you will find it will not seal because the gallery and the corrosion are too close. Yeah, you can have it welded and so on, but do you want to go there? Besides, the more you shave, the more you upset the valve timing.
    ACHTUNG ALLES LOOKENPEEPERS
    7,344
    With a DFZ head you'd have a CR of approx 7.5:1.
    205 heads are easy to weld. It just depends on how much you're prepared to spend. When the cost of repair is less than the cost of 2nd hand, somebody will repair it. Given the current rate of appreciation for 205's, this will be sooner than later. You can't expect parts to remain cheap whilst the cost of a 205 sky rockets.
    8,884
    DKZ on a DFZ engine will give well over 10 to 1 on its own. An extra 1 mm off would be crazy. I've found the even the standard 9.6 to one compression of a D6B (130 hp leaded engine) is on the limit with 98 octane. Sure you can back the timing off but that kills the performance.
    Quote Originally Posted by neilc View Post
    Jul 2014
    Sunshine Coast
    109
    Thank you all for your comments I will look around for a SI head.
    7,344
    Yeah, whoops. I went the wrong way. ie DFZ head on DKZ block.
    Jul 2014
    Sunshine Coast
    109
    Peter am i correct in saying a SI head is the same as a DKZ head with different valve springs? Any other differences?
    7,344
    And camshaft, that's all.
    Jul 2014
    Sunshine Coast
    109
