EW10J4S valve timing?
Results 1 to 10 of 10
    May 2011
    melbourn
    89
    Default EW10J4S valve timing?
    Is that timing correct?
    Sep 2003
    North Parramatta
    3,985
    Hi there,
    My 206 GTi180 Timing Belt procedure (from 2006) reveals this pic:
    I've never done a timing belt on an EW10J4S.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    May 2011
    melbourn
    89
    But I find that:
    Jul 2013
    Newcastle/ central coast
    1,649
    You need to get rid of that plastic water pump
    May 2011
    melbourn
    89
    why rid of that plastic water pump?
    901
    Because they tend to fail, the newer ones are metal.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Jul 2013
    1,649
    Sometimes even a new belt can cause noise from the belt even belt walk off
    Oct 2003
    613
    Quote Originally Posted by dmccurtayne View Post
    The belt will make noise if it is over tensioned.
    A belt will only walk if one of the tensioners or gears is misaligned, (like the adjuster on a belt sander).
    Jul 2013
    1,649
    Sorry (expert) but I was talking about the water pumps what do you think the plastic water pumps do to the belt when the new tighter belt adjusted correctly pulls the bearing sideways done heaps with that exact problem
    May 2011
    melbourn
    89
    but I just want to know the timing belt setting is correct or not?
