206 GTI running problem
Results 1 to 9 of 9
    9,177
    Default 206 GTI running problem
    Has anyone had any experience with the 206 GTI being very lethargic on opening the throttle quickly, sounds like the ignition is retarded (OK when idling though) or perhaps not enrichening the fuel under acceleration?
    Graham Wallis
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Graham,
    Isn't that the symptom they get when those bellows things (can't remember the name of them) near the intake plenum stuff up? I think there's two of them.
    Usually one blows and there appears to be no difference & then they twig the second one has gone wrong too.
    I think Brad once wrote up a posting about them.
    Alan S
    9,177
    Graham,
    Alan S
    I had no idea they were there, does sound a bit like it when the intake hose is removed.
    Graham
    1000+ Posts pgti6's Avatar
    May 2001
    1,612
    Graham Wallis
    I've had a similar problem with my GTi6.
    If the car has been unused for a few days, sometimes after starting, the engine doesn't want to rev unless lots of throttle is applied.
    If I leave it warm up for a few minutes, it returns to normal, so I've learned to live with it!
    Jeff
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    1000+ Posts gti138's Avatar
    Adelaide, South Australia
    1,885
    The only time my GTi has been a little sluggish to get going is if i'm in a hurry to get going and dont let the fuel pump prime properly before starting the engine. It tends to idle a bit roughly and then almost stall when you give the throttle a bit of a stab. I've now found it easier to simply let the fuel pump prime the system and then i'm right.
    Interesting about it being sluggish when you havent driven it for a while. I wont be driving mine for a week or so * * but i'll let you know what it's like when i get back behind the wheel.
    Murray : And there are flames coming from the back of Prost's car as he enters the swimming pool!
    James Hunt: Well that should put them out then!
    Mallala: 1:30.79
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Quote Originally Posted by gti138
    Ditto, but there was also a specific cold start patch for the ECU ..
    - XTC206 -
    Now this is a .sig
    rek
    rek is offline
    1000+ Posts rek's Avatar
    Melbourne, Vic
    1,388
    Quote Originally Posted by pgti6
    I have this too. Once , a long time ago, when they hooked up the diag computer thing to it, it was giving out intermittent oxygen sensor faults. They couldn't ever reproduce the problem though, so they never did anything about it.
    It seems to only happen once in a blue moon, and only once or twice during the first ~5 mins of driving in a cold morning.. I just live with it.
    Peter
    2008 Saab 9-3 1.9 TiD Sportcombi
    2011 Volvo C30 DRIVe 1.6D
    9,177
    Quote Originally Posted by rek
    The one I'm looking at does it all the time but it is worse when cold.
    I was thinking oxygen sensor and have recommended the owner take it to somebody who has diagnostic facilities.
    Graham
    May 2001
    1,612
    Graham
    I hope our oxy sensors aren't made by the same dodgy mob that made the COM2000's!!!!
    Jeff
    Lap times-
    Sandown 1 27.9
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
