The varnish that detailers use on engines
Results 1 to 11 of 11
  • 1 Post By pugwash
Thread: The varnish that detailers use on engines
    1000+ Posts Beano's Avatar
    2,895
    Default The varnish that detailers use on engines
    I have seen car engines (usually in secondhand car yards) that look pristine because they appear to have some kind of varnish applied to them. Like this :
    But when I smell it I cannot smell anything. Can anyone tell me what kind of varnish it is ? I am guessing acrylic clear top coat, but how well do you need to prepare the surface ? Because I imagine that unless it is spotlessly clean and dry to begin with, the final look will be awful...
    1000+ Posts driven's Avatar
    Apr 2005
    1,298
    Poms have the best stuff. Have used this on my Villiers stationary engine project
    Lacquer & Varnish :: Paragon Paint Products :: Stationary Engine Parts Ltd
    Needs to be high temp.
    Detailers just spray clear acrylic on. See underside of top radiator hose still dull grey
    Do test first to see how long it stays "shiny and clean"
    2,895
    The longevity is what I am worried about. A test would have to be for a long time.
    Perhaps my question should be : how long does it take till the acrylic starts to flake, peel, and look like crap ?
    I didn't know high-temp clear existed....just engine enamel. I'll go down to Repco and Supercheap....
    Jun 2014
    Sydney, NSW
    238
    I was at a paint merchants in Sydney recently picking up some "weld-through" primer for one of my projects, also went home with an aerosol of 'clear coat' {though not high temperature}. Got this because my Merc 124 has sun damage to one rear fender. I have to say that {after rubbing down & 'liquid cutting'} it initially went on & made the thing look 100% better - but then I got too impatient & sprayed a subsequent coat too soon {at least too soon for the sub-arcticness of Katoomba, was going by what it said on the tin}. Now I've got dribbles {& the car's not looking so good either}, so will have to rub down & reapply - maybe in a couple of seasons :-/
    I'm suspecting you may have to get onto an auto-paint specialist store, but try Repco / SCA - surprising what they do stock sometimes.
    Happy fixing,
    Rob
    may all your plans be cunning ones,
    Baldrick,
    fleet: 1989 Peugeot 505 GTi Wagon
    1969 Peugeot 404 Sedan
    2003 Smart 452 Roadster
    2005 MG ZR160
    1988 Mercedes 300E
    1953 Citroen 15CV (under Restoration)
    1953 Bristol 401 (under Restoration)
    That's one for each day of the week - I really should stop
    Aug 2016
    Sunshine Coast, QLD
    790
    Don't they just use a form of wipe on silicone.
    Awful stuff but makes rubber all shinny again 😀
    tweed heads
    1,428
    Tyre shine may have similar effect ,i have used it in the black plastic skirts /bumpers on my vw transporter to good effect, but its short term ,pugs
    Wildebeest likes this.
    May 2013
    NSW
    32
    Beano- try these guys:
    Clearcoat Paints - Automotive Finishes - Paints & Coatings @PPCCO online shop
    I've used several Eastwood paint products to restore a motorcycle and they have held up really well. I haven't used any of their clear coat products, but if I had the need I'd definitely look at this brand of products first.
    Perth Western Australia
    2,640
    INOX spray.
    Good for rubber, black paint underbonnet.
    2,895
    Some good ideas there. Thanks, dudes.
    tweed heads
    1,428
    I want to retract my post on tyre shine ,read the instructions ,i just did ,its seriously gnarly stuff ,wear a respirator and only use as directed , i will be in future, pugs
    Jul 2003
    bundaberg
    311
    Have seen tyre shine used on the interior of a dunger and it worked wonders on the door trims and dashboard, as least as good as Armourall. Not that I would use either on my cars however.
