Repairing a wheel rim - Melbourne
Results 1 to 14 of 14
Like Tree5Likes
  • 1 Post By robmac
  • 1 Post By Andrew Watkins
  • 1 Post By IWS
  • 1 Post By IWS
  • 1 Post By geodon
Thread: Repairing a wheel rim - Melbourne
    IWS
    IWS is offline
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,252
    Default Repairing a wheel rim - Melbourne
    A wheel rim on my daughter's Megane is damaged. See photos.
    Anyone have experience in having these rims repaired - in Melbourne?
    All advice/experiences will be valuable to hear.
    Ian.Repairing a wheel rim - Melbourne-20180612_210455.jpgRepairing a wheel rim - Melbourne-20180612_210447_resized.jpg
    871
    There's a place in Richmond, I think church st. No actual recommendation though
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    902
    Following
    18,043
    Quote Originally Posted by IWS View Post
    Ian.Click image for larger version.
ID:	106735Click image for larger version.
    https://www.easternwheelworks.com.au/
    Contact Us | Ajax Wheels
    I've used Ajax a few years ago, run by two grumpy old men, who know their stuff. However they tend to work when they want to and can take a while to get the job done.
    That was at their old location off Nepean Hwy, down the road from the Moorabbin Bowling Center. Things have probably changed.
    A neighbor used EWW and got a good job.
    IWS likes this.
    with apologies to Judy Grahn
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,234
    Neway wheels in heidelberg do a good job
    Sent from my SM-G930F using aussiefrogs mobile app
    406 D8 V6 manual
    1000+ Posts pgti6's Avatar
    May 2001
    1,566
    I've used Neway a couple of times with good success on alloy rims.
    Lap times-
    Sandown 1 27.9
    Phillip Island 1 53.8
    Previous Frenchies-
    1988 205Gti
    1998 306 GTi6
    1997 306 N5 sedan
    1996 306 N3 XT hatch
    Mar 2013
    olinda victoria australia
    613
    Default Wheel repair
    Agree with suggestion of Beway
    First used them 40 years ago and have never let me down
    They won’t bodge - if wheel can’t be safely repaired they will tell you- but are flexible and imaginative with unusual tasks
    Prices are fair - neither stupidly high nur stupidly low, both of which are important
    Fairly quick tyrnaround too
    Andrew
    IWS likes this.
    IWS
    IWS is offline
    Feb 2005
    Hawthorn East, Vic.
    1,252
    Thanks all for advice. I'll go with Neway - they are well located for me and from all reports do a good job. I'll report back on the experience.
    Ian.
    1000+ Posts driven's Avatar
    Apr 2005
    1,281
    Any tyre place can get alloys fixed, can do deals with a tyre at same time
    IWS
    IWS is offline
    Feb 2005
    Hawthorn East, Vic.
    1,252
    Progress report.
    Dropped the wheel off Neway today. Thinks it can be fixed. Cost: $115. Turnaround - a few days.
    I'm hopeful.
    Ian.
    CEyssens likes this.
    Tadpole maxsp33d's Avatar
    Mar 2018
    Australia
    1
    Would suggest to ask the expert but as per seeing the photo you have shared, it could fix and have a wheel balancing to secure the efficiency of the rim.
    IWS
    IWS is offline
    Feb 2005
    Hawthorn East, Vic.
    1,252
    All fixed - by Neway. Price as quoted - discount for cash. Done in a couple of days.
    Neway were good to deal with. The place in Richmond (cant remember their name) didn't bother to respond to my inquiry. If I need wheel repairs I'll go back to Neway.
    Ian.
    s9810588 likes this.
    Member s9810588's Avatar
    Sep 2013
    35
    A bit too late of a response but could inform the next person.
    The wheel repair place in Richmond you mentioned is probably Wheels Solution; avoid them!
    Had a set of wheels repainted by them, cost $1300, and can't say I'm 100% happy. Was going to pick up the car, they lock my key inside the car. Noted the clear coat didn't cover a lot of area and the paint felt rough here and there. No worries, they put more clear coat on.
    Finally got a second key, picked up the car, drove ~35km home and the car felt weird. Checked the wheel bolts - all finger tight only, some undone by 1-2 turns. Bloody dangerous!
    Closer inspections revealed paint runs here and there from spraying too much paint. Won't be going back there or recommending it to anyone.
    Jan 2013
    Geelong
    435
    I used Neway for years, mainly for wire wheels.
    They got lots of business from me in the 90's with 3 MG Midgets in the family!
    Always had good results.
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
