604 fr shock inserts
Results 1 to 10 of 10
    Feb 2012
    MUDGEE/NSW
    118
    Default 604 fr shock inserts
    Does any frogger know whether I can use the 604 fr shock inserts in a 505 GTD turbo front suspension rebuild.?
    Sent from my SM-T550 using aussiefrogs mobile app
    Jul 2003
    107
    I always assumed 604 and 505 strut inserts were the same but I don't know for sure. I have some 604 KYB strut inserts somewhere which I could measure if that would help.
    Dec 2002
    2,513
    Late 504, 604 and early (pre-October 1985) 505s use the same strut inserts.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    Feb 2012
    MUDGEE/NSW
    118
    I had a quick measure and the 604 insert seemed to be shorter..... I Mean the extended length seemed to be slightly shorter than a 504/505 insert. Would this matter on a 505 GTD turbo?
    Jul 2003
    107
    I guess it depends how much its shorter by. A few mm wouldn't make much difference but over say 10mm it may be a problem as it'll reduce the spring travel by the amount it's shorter by. Is it a factory Peugeot 505 strut youre comparing the 604 strut to? Because if its an aftermarket 505 strut it may not be the correct length anyway. I'll measure the KYB 604 strut i have tomorrow so that you have another measurement to compare yours to.
    Jul 2003
    107
    Here are the measurements I got from my KYB 364002 WA-13 strut inserts: overall length is 660mm and piston alone is 207mm.
    Attached Thumbnails Attached Thumbnails 604 fr shock inserts-604-kyb-strut-insert-364002-wa-13.copy3.jpg
    Feb 2012
    MUDGEE/NSW
    118
    My Boge 604 struts measure 260mm extended and body is same length as 504, 505 (I'm not sure which).Sure are longer than the 207mm, so they should be ok for the 505 GTD turbo?
    Jul 2003
    107
    It seems odd that there is so much difference between the KYB and the Boge, and that the std 505 strut you have is even longer. Maybe the 604 strut I have is not the std length. If your strut is only slightly shorter than the 505 strut then it will probably work ok but I'd compare it to the strut you remove from your car and make sure it's aproximately the same length.
    Feb 2012
    MUDGEE/NSW
    118
    Yes that sounds like the best idea, remove 505 struts on car and compare. Should happen in a couple of weeks.
    Feb 2012
    MUDGEE/NSW
    118
    YES.....they fit.Having now rebuuilt the front end, I will now have to investigate why there is coolant emerging from the tailpipe. There was a perished water bung on the cooling systems so should I assume a blown head gasket..?Hoping to find a good diesel mechanic in the Mudgee area.
