Power steering
Results 1 to 3 of 3
Thread: Power steering
    Fellow Frogger! mmm...CORNERS's Avatar
    Epping, Sydney
    574
    Default Power steering
    This isnt exactly frog relatd but...My girlfriends Mirage has power steering and she hates it, her old mirage didnt, and she liked the solid feel with no assistance.The question is, can you remove power steering with no adverse effects? (her old one was written off by a guy in riced civic...didnt understand what a red light is!)cheers!
    1000+ Posts Haakon's Avatar
    May 2002
    canberra...
    8,747
    Should be easy enough - just go and buy the manual rack and bolt it in, and unbolt all the hydraulics and the pump. A wrecker will no doubt swap a power rack for a manual one.
    Just disconnecting wont be good, as the power rack will be a higher ratio and a pig to drive if not powered.
    Also check that Mitsubishi didnt run different caster and/or camber setting b/w manual and power steer, and if so, then check if its adjustable. The power model may run more caster which is good for handling but not for light steering.
    However, a much better option is to flog it off and buy a real car
    Epping, Sydney
    574
    However, a much better option is to flog it off and buy a real car [/QUOTE]
    too true, she actually dosnt mind the look of the Megane.
