205 after market oil cooler location
Results 1 to 8 of 8
    1,684
    Default 205 after market oil cooler location
    After info or best advice on mounting an after market oil cooler to the gti 6 in my 205, location is going to have to be under drivers headlight as there is precious little room elsewhere that fits, as I have tried already to keep it close by the filter etc.
    It a mocal filter that fits to a thermostat to open at 80 and is on the end of about 0.75m of hose on both fittings.
    The principal behind this is to reduce overall heat load on coolant system that is traditionally used to give best chance of air con working and cool oil for engine.
    307 HDi wagon
    407 HDi wagon
    1,684
    How about a welded fram under the wheel arch on the brace that sits there? Short path and solid mount with rubber buffers.
    307 HDi wagon
    407 HDi wagon
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,322
    205 after market oil cooler location-18822ae0-b7ba-41af-bdc4-2a02e330ecc8.jpegHave you lowered the rad?
    You could ppace it up and to the right ‘next to’ the inlet manifold?
    Mabye less room obviously but you get the point.
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
    1,684
    No I haven't its all factory, I get the idea but its getting very squeezy now. Not much room left for anything.
    307 HDi wagon
    407 HDi wagon
    Nov 2003
    Bondi
    3,322
    Or from the bottom on the nonstructural crosmember the rad setup sits on.
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    1,684
    Had it there but mounted a little too high interfering with the lower part, a lower mounted cooler will clear this so a metal bracket with rubber mounts is on the cards along with the lines which folded back to allow engine movement (after I destroyed last revision, thanks Scotty)
    307 HDi wagon
    407 HDi wagon
    18,774
    If it is mounted under a mudguard the fins will fill up with mud and crud.
    I found out by hard experience when putting air con condensers under guards.
    And gravel thrown up by the wheel has a tendency to put holes in modine tube type condensers
    1,684
    Fair comment and logical, did not enter my mind which is the ultimate limitation? Back on front close as possible must be best.
    307 HDi wagon
    407 HDi wagon
