R8 and Caravelle hubcap noise and solution
Results 1 to 8 of 8
Like Tree2Likes
Thread: R8 and Caravelle hubcap noise and solution
    11,302
    Default R8 and Caravelle hubcap noise and solution
    Well, after dismantling one corner for an 'obviously wheel bearing' noise, it wasn't.
    I'd replaced the old hubcap rubber seals, now available again at a price ex-France, with split pvc tubing.
    To cut a longish story short, Clark Rubber has a good square-section U seal in rubber that works really well.
    It is Ref 31679, "Weather Strip 2.5/7T N010 U shape". It fits nicely on the hubcap, with the thin side under the rolled edge and the thick side as the cushion between hubcap and wheel. Should be available nationally under that number and you need the best part of 4 metres, at about $10 per metre.
    Attached Thumbnails Attached Thumbnails R8 and Caravelle hubcap noise and solution-r8-hubcap-clark-rubber-ref-31679.jpg   R8 and Caravelle hubcap noise and solution-r8-hubcap-rubber-fitting.jpg   R8 and Caravelle hubcap noise and solution-r8-hubcap-new-seal.jpg
    Renault 4CV 1950 (R1062)
    Renault R8 1965 (R1130)
    Feb 2005
    rosevale/tasmania
    2,872
    Then again, just discard the hubcaps?
    11,302
    I wondered who would be the first to suggest this. They do look good without, I agree.
    Good lateral thinking!
    Attached Thumbnails Attached Thumbnails R8 and Caravelle hubcap noise and solution-refurbished-r8-wheels-nov-2017.jpg
    Brisbane/Australia
    2,200
    Would you really want to go around with your nuts exposed?
    It's not a good look.
    11,302
    Quote Originally Posted by REN TIN TIN View Post
    Would you really want to go around with your nuts exposed? It's not a good look.
    I wondered who would be the first.....
    Feb 2005
    rosevale/tasmania
    2,872
    speak for yourself :-)
    Brisbane/Australia
    2,200
    Well the bait was cast and the bait was taken.
    No surprise there.
    I remember the good ol' days of the early 80's when Australia still made cars and you could buy a brand new Fuego, sigh. As most of you know, it seemed the car manufacturers were either trying to save money or thought it was a good idea to have hub cap held on by the wheel nuts and just covering the centre of the wheel, well for the cheapies in the range at least, SL, GL, TX, etc. Not having a full wheel hub cap probably saved them at least 5 cents per wheel.
    Alloys with exposed nuts, good look. Steel wheels with exposed nuts, not a good look (unless the nuts are designed to be exposed).
    I suppose I shouldn't talk, my 12 has a full-wheel hub cap but with fake nuts, but the nuts are stainless steel (The bloody things rattle too).
    Or get yourself some fancy nuts and ditch the hub caps.
    Feb 2005
    rosevale/tasmania
    2,872
    As to what is a "good" look & what not: de gustibus non est disputandum or, if you prefer, chaque un a son gout or, beauty is in the eye of the beholder.
