504/505 diff ratio identification
Results 1 to 7 of 7
    Dec 2010
    TAREE AUSTRALIA
    40
    Default 504/505 diff ratio identification
    Hi,
    can anyone help with identifying these diff ratios please.
    4A78609
    S43270R
    thanks in advance
    SWOTR
    3,431
    Does this help?
    504/505 diff ratio identification-diffs-dec-84.jpg
    18,428
    Sometimes you see the ratio stamped on the end of the splined input shaft.
    In the format A X B
    Where a & b are the number of teeth on the gears.
    1000+ Posts Beano's Avatar
    2,985
    ^ That's the only place and format in which I've seen the ratio in 504s and 505s.
    My 505 GR auto has a 4.11 diff, and on the very front of the splined input shaft is stamped "9 x 37".
    You divide 37 by 9 and get 4.11.
    Dec 2010
    TAREE AUSTRALIA
    40
    Thanks for your replies. There are no numbers stamped on the end of the spline hence I've supplied the numbers stamped on the housing.
    Fellow Frogger! Rally's Avatar
    Pearl Beach NSW
    525
    Quote Originally Posted by justpugs View Post
    The numbers will be there , sometimes very lightly punched and hard to read ,. Give the end of the pinion shaft a good clean and put your glasses on.
    Peugeot 504 Rally car V6
    Peugeot 504 LTI
    Peugeot 504 Ti
    Citroen SM
    Citroen Light 15
    Peugeot 406 SV 5 speed
    Citroen DS23 EFi Safari
    Toyota Land Criuser V8 Super charged ( to tow the rally car )
    Rally with www.AMSAG.com.au
    Dec 2002
    2,516
    Quote Originally Posted by Rally View Post
    I've noticed that very early hypoids (404 commercials - utes and wagons) don't have this stamped. But given the numbers on JustPugs' diffs (a standard 504 diff and a 604 V6/505TD diff), yes, the stamps will be there.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
