BSI Lexia Diag on the bench
Results 1 to 7 of 7
Like Tree2Likes
  • 2 Post By haydent
Thread: BSI Lexia Diag on the bench
    Nov 2013
    NSW
    39
    Icon3 BSI Lexia Diag on the bench
    Just wanted to share my hookup for connecting to a BSI out of the car on the bench. Still need to label the wires in the photo. Will do.
    BSI Lexia Diag on the bench-dsc_0382.jpgBSI Lexia Diag on the bench-dsc_0383.jpg
    dcc236 and dimistyle like this.
    Aug 2016
    Sunshine Coast, QLD
    848
    That's a good start, any reason you have gone to this extent? good to be documented as even the French sites don't go to this extreme measure to isolate a fault/s
    Cheers, Dimi
    Nov 2013
    NSW
    39
    In practise just to see that i could. It was a spare BSI/ECU combo i bought off ebay. In theory though id thought it would be good to know the KM of said unit in case it was higher before install, as maybe one might not want that.
    Aug 2016
    Sunshine Coast, QLD
    848
    Great idea to be able to actually read the config, pin code and km. You may actually be able to re-write the km if you have the eprom writer!
    Nov 2013
    NSW
    39
    would like to know if there is an eeprom writer you can use via can or k bus without having to desolder it
    Aug 2016
    Sunshine Coast, QLD
    848
    You will need to do some homework to find the type of eeprom used.. plenty of examples and networks on the web the kids use.
    This is a good example upa, never done ir tried myself but understand both bsi and cluster need to be done or otherwise higher mileage will always be recored!
    http://blog.obdii365.com/2016/05/09/...rog-xprog-upa/
    Nov 2013
    NSW
    39
    ok thanks, will pass this on
