20056 Berlingo Rear Susspension
Results 1 to 10 of 10
Like Tree2Likes
  • 2 Post By GRAHAM WALLIS
Thread: 20056 Berlingo Rear Susspension
    9,103
    Default 20056 Berlingo Rear Susspension
    Would a 2005 Berlingo have the torsion bar rear suspension? Need a pair for my 309 rally car and have found a 2005 model being wrecked.
    8,504
    9,103
    Thanks, did the trick, hope we got the 800kg versions here.
    9,103
    Got them out today, grovelling around in the dirt and heat at Imlach's
    However, the total monetary cost was $27 for a 1.3mm upgrade to the 309, can't complain about that!
    By the way no idea why the van was being wrecked, maybe a dead MA gearbox?
    seasink and bluey504 like this.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,299
    Nice GW
    I had them on a 309 beam in a 205 at one point.
    There also good upgrade for 405 rear beams as there the same length.
    98 Xantia CT
    94 205 Gti Classic #9
    92 405 Mi16
    87 205 GTi Race Car
    9,103
    Yes, by a fluke all three have the same length bars. The 405/Berlingo suspension is totally different from 309/205/306 which makes it even more of a coincidence.
    Nov 2011
    Norway
    60
    The back axle on the Berlingo is basicly the same as on the 405 witch were produced at the same time as the 205 and 309 so its no coincidence.
    9,103
    You're right, the coincidence is more that the 309 uses the same length bar.
    Nov 2003
    Bondi
    3,299
    Yep. You can essentially just replace the entire rear of a 405 with a berlingo rear end as an 'upgrade'.
    98 Xantia CT
    92 405 Mi16
    87 205 GTi Race Car
    9,103
    After you remove the brakes and replace with discs. I wonder whether the bigger Berlingo drums would fit a 205 Si rear end? Could be a good upgrade for motorkhanas, I need to give the lever a big tug in my Si even with new handbrake cables.
